Author Topic: ROMS and revisions latest best??  (Read 803 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: March 28, 2007, 11:20:58 pm »
Is it best to use the latest ROM revision?  MK has like 6 or something, so should I use the latest one?
I b**ch. People listen!!
Jeff AMN
    • Gamer Theory
Re: ROMS and revisions latest best??
« Reply #1 on: March 28, 2007, 11:31:22 pm »
Depends on your version of MAME...
squirrellydw
« Reply #2 on: March 28, 2007, 11:50:43 pm »
113
shorthair
« Reply #3 on: March 29, 2007, 12:19:53 am »
Do you mean version or set? If the latter, it's really up to you.  For example, both Asteriods and Deluxe have two sets.  Supposedly there are differences, but I haven't really seen them.
squirrellydw
« Reply #4 on: March 29, 2007, 12:30:51 am »
Both really, set 1, set 2  Mk has revsion date, revision later date, revision ever a later date.  like 8/9/04, 9/10/04, 12/9/06 for example
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
« Reply #5 on: March 29, 2007, 12:38:04 am »
I've seen a revision of MK that was a hack.  Can't remember off the top of my head, but it was on a dedicated cab and had the roms changed to a version called "Immortal Kombat" and has you fight bosses only and use kill moves anytime.
Guess it depends on whether you want to play the original version or not.  I'd do some research on each game to find out what the differences are between revisions.
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
MaximRecoil
« Reply #6 on: March 29, 2007, 07:26:35 am »
I usually just go with whatever revision is the master ROM.
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: March 29, 2007, 07:47:41 am »
Look the game up in MAWS or in the History.dat file or at http://www.arcade-history.com/index.php?page=database
I'm not a MK fan, but sometimes you might want the later version or sometimes the earlier one.
For example, early ROMS of Asteroids prevented the ship from being hit if it was behind one of the player score areas.  Later ROMS disabled this bug/feature.
I play an obscure version of Gun.Smoke (gunsmoka) that has levels 3 and 6 swapped b/c the actual machine that I played the game on years ago had this version in it.
In other cases, the difference between versions may just be the text on the copyright screen, or the "Winners Don't Use Drugs" screen at the beginning, so it really doesn't matter.
squirrellydw
« Reply #8 on: March 29, 2007, 10:24:06 am »
thanks, I always forget about MAWS.  Very helpful
