Main > Main Forum
Silly T-Molding Question
VMJ Team:
I'd t-mold all the way around...even on the bottom. It helps when sliding your cab around on carpeting, plus it provides a buffer for damage when moving the cabinet.
Wienerdog:
Another reason to route all the way around is that even if you decided not to put molding on the bottom, you would have the slot in place if you change your mind later.
hedge:
Thanks for the advice. I have decided to route all the way around. That's the way I was leaning, but needed some reassurances... :)
thedemo:
Word of advice
Cut the slots before you assemble the cab. Its alot easier to cut the slots when you can lay the pieces flat on sawhorses than when its assembled and standing upright.
hedge:
I just asked this in another thread, but how deep should I route the slot around the sides? The 1/16" bit I bought will cut 1/2" deep. Will this be ok?
Thanks!!
