Author Topic: Mounting the Ultimarc Ultras(t)ik (with the silent 't')  (Read 2225 times)
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
« on: March 21, 2007, 07:19:55 pm »
Does anyone have a screenshot of how the Ultrastick looks installed from the bottom. I'm not sure which way the usb and pin connector should be pointing. Facing Front or Back, that is the question.
Thanks.
« Last Edit: March 23, 2007, 01:38:30 pm by (+_+) »
This plan is so perfect, it's retarded. -- Peter Family Guy
Aurich
  • Last login:September 12, 2021, 01:34:32 am
Re: Mounting the Ultimarc Ultrasik
« Reply #1 on: March 21, 2007, 07:47:45 pm »
The USB connector is facing towards you, on your left, the pin connector is towards you on your right.
(+_+)
  • Let me splain.
« Reply #2 on: March 21, 2007, 08:14:13 pm »
Thanks Aurich!!
shatter
  • Last login:June 27, 2009, 02:07:12 pm
« Reply #3 on: March 22, 2007, 06:24:31 pm »
The good news is that even if you mount it incorrectly, all you have to do is unscrew the PCB and rotate it into the correct position and you are back in business!
blueznl
« Reply #4 on: March 22, 2007, 07:09:21 pm »
>> ( Re: Mounting the Ultimarc Ultrasik )
Calling it the UltraSi(c)k may cause some raised eyebrows  :)
(+_+)
  • Let me splain.
« Reply #5 on: March 23, 2007, 01:33:34 pm »
That's pretty funny. I hope it turns out to be Ultrasik and raise more than just eyebrows. Get your minds out of the gutter. I mean game scores.
