Author Topic: CP Design Software?  (Read 997 times)
englishw
  • Last login:October 05, 2010, 06:11:52 pm
CP Design Software?
« on: March 21, 2007, 11:53:16 am »
I am using Photoshop to design my CP and it isn't working out very well. Any recommendations for software to use to design my CP? Or designing my cab?
Kaytrim
  • I'm too nice a guy
Re: CP Design Software?
« Reply #1 on: March 21, 2007, 11:58:03 am »
I use CP Sketcher.  It'll give you an accurate layout and measurements to cut your CP.  You can even import your artwork into the background to get a good feel for what your CP will look like when finished.  Google is your friend.
TTFN :cheers:
Kaytrim
**edit, forgot to mention that CP Sketcher is freeware.  ;D
« Last Edit: March 21, 2007, 12:08:47 pm by Kaytrim »
Jeff AMN
    • Gamer Theory
« Reply #2 on: March 21, 2007, 12:06:03 pm »
Heh, until I went with knievel for my CP services, I was just using some posterboard, rulers, pencils, and some erasers. Probably not the most elegant method, but seemed to work well enough.
Racer_X
  • Last login:April 12, 2008, 11:19:44 am
« Reply #3 on: March 21, 2007, 12:26:57 pm »
I used the visio templates off of the arcade controls main page.  I'm not done, however it worked very well to do my design.  I printed it on a plotter, taped it to some cardboard, and now I actually have a working control panel!
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
« Reply #4 on: March 21, 2007, 03:38:55 pm »
adobe illustrator works very well. it's expensive, probably not worth buying just for this, but it's a widely-used program and you may be able to borrow time on a work / school / friend's computer.
my web page (linked in my signature) includes an illustrator-editable PDF file, from which you can grab template elements (look in the "download" section at the bottom of the page).
to see my "Frankenpanel" and design notes, click here.
lokki
  • Last login:June 29, 2017, 12:57:48 pm
« Reply #5 on: March 21, 2007, 06:02:20 pm »
what about
http://www.sketchup.com/
Pretty easy to use and very powerful
