Author Topic: Mala and Zsnes Issues  (Read 2086 times)
berdat
  • Last login:March 22, 2007, 01:45:32 am
« on: March 20, 2007, 10:18:54 pm »
Hi guys im fairly new to Mala, I have it set up running MAME, ATARI2600, and SEGA Emulators perfectly thanks to UncleT’s instructions.
BUT i seem to be having trouble running my Nintendo roms, I am running Zsnes and have everything in their correct folders, but when choosing the Nintendo ROM. Zsnes seems to open up in its own little window (not full screen).
Then if I try to get out of zsnes and back into mala I press the Esc key, but it only exits out of the ROM, leaving the pink and purple main screen for Zsnes, ? ? Is this correct, :dunno im not sure what I have done wrong
Please please please HELP !  :)
« Last Edit: March 20, 2007, 10:58:12 pm by berdat »
4Aaron GE
  • Last login:July 22, 2013, 10:27:07 pm
Re: Mala and Zsnes Issues
« Reply #1 on: March 21, 2007, 12:57:52 am »
What version of Snes are you using?  Zsnes (dos), or Zsnesw (windows)?
Either way, I you're supposed to manually quit from either version with the quit command from the file dropdown menu.
Now as far as the video goes, you can default to a fullscreen resolution in the config -> video menu.
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #2 on: March 21, 2007, 01:17:54 am »
I answered this in the software forum...
http://forum.arcadecontrols.com/index.php?topic=64588.0
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
unclet
« Reply #3 on: March 21, 2007, 06:41:41 pm »
Under the "MISC/Game Keys" menu within ZsNes you can map the key you want for EXIT.   I use "Q" myself.
As for going full screen under the "CONFIG/Video" menu within ZsNes, I selected "800x600 S FULL" as my setting.   I believe I simply tried a bunch of them and kept the one I thought worked best for me.
berdat
« Reply #4 on: March 21, 2007, 07:04:22 pm »
THANX GUYS !! .... all good  ;D
thanks for all your help !!!
Organic Jerk
    • OmeshPersaud.com
« Reply #5 on: March 21, 2007, 08:03:51 pm »
True, but it doesn't work when trying to map Esc, as the Esc key is used to "cancel" your mapping, so the only real way is to edit the cfg file manually and use the key's "scancode" .
berdat
« Reply #6 on: March 22, 2007, 01:45:22 am »
yeh thats what i had to do .. coz i wanted to use the ESC key to exit
But thanks for the Replys
problem solved
