Main > Everything Else
Stupid stupid plows
billf:
--- Quote from: ChadTower on March 20, 2007, 02:26:51 pm ---Put up something that has no obvious purpose other than to damage a vehicle, and someone hits it, you're the one to blame.
Put up something that has a decorative/other obvious purpose, and someone hits it, they are to blame, even if it's the same object as above with a smiley face painted on it.
This quote from Chad is exactly what I was going after in my comments. Kudos to Chad for putting is so succinctly. DK, I was the first person in this thread to use decorative and I meant decorative. I'm not sure what you're implying, but I meant decorative. There are plenty of decorative brick/split face blocks on properties to define the lot lines. This would clearly mark where the private property is versus public right-of-way. I was not insinuating putting up a brick wall with the sole purpose of catching "bad drivers" or bad plowmen. Or intentionally trying to disable or maim someone in the process.
shmokes:
BTW, Drew. Maybe I should remind you that, while I think you are largely full of hyperbole here, you and I have spent exactly the same amount of time in law school.
DrewKaree:
--- Quote from: shmokes on March 20, 2007, 07:07:12 pm ---
So I'd make a better lawyer than you, you think, or are you just reconsidering the profession you're wanting to get into?
shmokes:
Neither.
DrewKaree:
Does this mean I can still expect you to defend me in any cases I might need you for (the insanity defense only, please, and I don't care if it IS just a parking ticket, dammit!)?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
