Author Topic: touchdown fever optical rotary joystick (ikari like) spinner specs  (Read 2902 times)
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
Does anyone know anything about the touchdown fever optical rotary joystick?  Like what the pinout of the spinner is?  How many pulses per revolution?  What the electrical specs are for the pulses (e.g. low pulses/high pulses)?  Can this be connected directly to a opti-pac or opti-wiz or TT2 opti-wiz?
Thanks,
If I do not respond to your post in a timely manner, feel free to PM me.
shorthair
Re: touchdown fever optical rotary joystick (ikari like) spinner specs
« Reply #1 on: March 18, 2007, 12:33:15 am »
Man, that seems like a simpler design than the Happ....
Crowquill
  • Last login:December 03, 2021, 05:02:15 pm
« Reply #2 on: March 18, 2007, 12:50:26 am »
Have you checked it against the wiring for an Ikari LS-30?
According to the manual that I found at crazykong.com, this joystick is SNK part number LS-40.  Surprisingly the manual doesn't give the pinouts though.
EDIT: Just noticed that in the Wiki it states that the Touchdown Fever sticks are actually optical. It also states this though:
The Touchdown Fever games used a Happ Optical rotary, which is basically a Happ Super with the encoder wheel and optics added to the bottom
Maybe Touchdown Fever 2 did, but that definitely doesn't look like a Super. It does match the pictures in the manual.
If that's the original wiring harness, Red and black should be 5V and Ground respectively leaving the other two to be the signal and clock wires. That makes sense as that would match the pinouts for the optical boards on Happ, Atari, and Wico trackballs.
« Last Edit: March 18, 2007, 01:06:57 am by Crowquill »
rockin_rick
« Reply #3 on: March 18, 2007, 01:55:48 pm »
Thanks, I hadn't yet been able to track down a manual.  Also never heard of that site - there's some good stuff there...
I'm not sure about assuming the red and black, though.  Makes sense, but I've seen way too many games where red and black were not pos and gnd while some other colors were.
I'll try looking for LS40 info.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #4 on: March 18, 2007, 04:12:35 pm »
Wiki is now fixed.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: March 19, 2007, 03:15:09 pm »
Hmm, the manual calls it "LS40 - 24", and the "standard" old-school optical rotary was called "loop 24".  I'm guessing these two are the same?
Technical Note:  The "other two" wires in happ, atari & wico TB are not signal & clock, but x1 & x2 (or x & x').  There are two optical sensors per axis (often both in one case, though); one wire is the raw data from the first sensor, the other wire is the second.  I don't have the loop-24 stick, but happs optical rotary is like the TBs.
If it was actually "signal & clock" wires, which usually means direction & speed in optical sensors like these, extra processing would need to be done on the sensor board.  Which is why it was rarely done in arcade hardware.
Minor point, but the difference is why the mouse hacks are possible in all but a few sensor boards.
Robin
Knowledge is Power
rolins
  • Last login:July 17, 2011, 05:26:08 pm
« Reply #6 on: June 08, 2009, 11:48:37 pm »
Did anyone figure out the pinout to this joystick? I want to try and connect this to a Cal .50 game.
