Main > Project Announcements |
uroMAMEstyx : Project done (2007.12.10) |
<< < (12/49) > >> |
Knievel:
Too bad about the scuff but that is one sweet looking panel! If it does bother you something like this(with a little modification)might cover that rough edge up.. http://www.t-molding.com/store/product.php?productid=16&cat=5&page=1 BTW I'm not sure if you are aware of this but they make laminates with metal finishes now. There is one that's a dead ringer for stainless steel, very easy stuff to work with. |
superbigjay:
--- Quote from: Knievel on April 22, 2007, 04:27:41 pm ---Too bad about the scuff but that is one sweet looking panel! If it does bother you something like this(with a little modification)might cover that rough edge up.. --- End quote --- Thanks for the hint, I'll keep that in mind if the scuff is too visible when the plexi is installed. --- Quote from: Knievel on April 22, 2007, 04:27:41 pm ---BTW I'm not sure if you are aware of this but they make laminates with metal finishes now. There is one that's a dead ringer for stainless steel, very easy stuff to work with. --- End quote --- Nooooo! :dizzy: I knew about the metal vinyl (like I've used as a reflective background on the LED mounts), but laminates... Definitively a good option for real stainless steel: - easier to work with - probably less expensive - no finger prints Cheers :cheers: JF |
Knievel:
Yes I made a bar for someone using it, really easy to work with. On the downside it's actually more expensive than real stainless. :P http://www.formica.com/publish/site/na/us/en/index/metal/colors_collections0/metal_laminate.detail.2178.0001.html |
superbigjay:
--- Quote from: Knievel on April 22, 2007, 06:37:24 pm ---On the downside it's actually more expensive than real stainless. :P --- End quote --- Well, it's good to know there're alternatives. It took me 33 years to need a sheet of stainless. Hopefully, that kind of laminate will be cheaper in 33 years from now >:D Jay |
superbigjay:
Houray! I was able to finish and try my CP. Well my mini CP ::). In fact, it was just a trial to see how to hook the keywiz with the happ 360 and pushbutton. So I did a small CP : 1 joystick + 2 buttons and try a few games... For some reason my old school favorite "mat mania" didn't work properly, but I'll check that later when I get my CPU for the cab... So here's a snapshot of it with shinobi in the background... PS: just 1 joystick and 2 pushbuttons and I was able to make a mess... Can'r wait when the real CP will be ready with 3 joysticks and about 30 buttons... :o Good night! Jay |
Navigation |
Message Index |
Next page |
Previous page |
