Main > Main Forum
Smooth straight cuts in MDF?
Pages: << < (3/3)
mpm32:
If you don't see yourself doing much woodworking after your cab, why don't you go to a rental place and rent the tools you need.  Most rental places will have better quality tools than you can buy cheaply.
rhoelsch:
Ok, so the leader seems to be circular saw w/ carbide blade and a straight edge.  I'll use the jig to cut the hole for my coin door (or should I still invest in a router?).  Guess I'll get a circular saw that can angle 45 deg. for mitred corners fitting together...but then again, I'll have to get something to cut slots for the T-molding, probably look into renting a router...
Thank you boys.......Thank you
Pages: << < (3/3)
Go to full version
