Main > Everything Else
Finding an exhaust leak
<< < (6/11) > >>
shardian:
Check for oil leaks around the turbo. Odds are you are getting oil dripping down onto the exhaust manifold, resulting in smoke getting into your ventilation system. Why do I know this? Well because I am getting smoke clouds coming out of my vents right now in mine due to the same problem. Did you check the pcv hose system like I suggested when you first got the car?
DrewKaree:
--- Quote from: shardian on March 13, 2007, 02:33:57 pm ---
I'ma hafta start wearing Depends around here.  I think I just wet myself from laughing too dang hard! :laugh2: :laugh2: :laugh2:
USSEnterprise:
--- Quote from: shardian on March 13, 2007, 02:33:57 pm ---Check for oil leaks around the turbo. Odds are you are getting oil dripping down onto the exhaust manifold, resulting in smoke getting into your ventilation system. Why do I know this? Well because I am getting smoke clouds coming out of my vents right now in mine due to the same problem. Did you check the pcv hose system like I suggested when you first got the car?
Yes, and I replaced most of it with one of the FCP Groton Kits. I do have a leak  (no oil on driveway) on the turbocharger's oil line, but the car doesn't smell like burning oil.
ChadTower:
After reading through this thread, this kid either has 48 hours a day of free time or he considers his free time absolutely freakin' worthless.
Just to drive the tip of this point home further than these guys already have:  don't get belligerent with the people you are asking for help.
shardian:
--- Quote from: USSEnterprise on March 13, 2007, 04:11:59 pm ---
The return line on the bottom, or the big intake hose on the side?
If it is the bottom return line, then there are $4 worth of seals you can get to fix that.
As to locating the leak, start the car on a cold morning and take a look under the car for exhaust leaks. You should be able to see them then.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
