Main > Main Forum
I know this is stupid, but I don't want to take any risks: . . .
paulkortne:
do i have to push that square thing onto the stick pretty hard? Cause it doesn't seem to be going down all the way.
SirPoonga:
I'd thjink it'd fit snug, but not extremely hard. Though I look at oscarcontrol's reviews and I don't see the e ring.
Rocky:
paulkortne,
You must compress the spring with the actuator (square thing) in order to get the E-clip on.
The E-clip keeps it from coming apart.
Don't worry about using too much pressure. These things are made to have hundreds of teenagers abuse them in arcade games ;)
Seriously, you have to compress it in order to get the clip on.
Rocky
gnateye:
which is next to impossible to do unless you have something against the stick top while you push the acuator (square thingy) down on the stick, while you force the acuator down with one hand, slip the eclip on with he other, you dont have to get it on the whole way at first just enough to hold it until you can let go of the jstick and it doeesnt fly up in the air, then use a needlenoise plyers to force the eclip the rest of the way on.
hopethat helps.
paulkortne:
I got it on, and it's working. Many thanks to everyone who replied. :)
