Main > Consoles
Xbox 360 Controller Hack Tutorial -- Wireless Hack Now Available!!!
<< < (55/86) > >>
HaRuMaN:
--- Quote from: Nakune on June 03, 2009, 06:40:06 pm ---And...d'oh. That did it, and it works great now.
 ;D  Sometimes it's just the little things...  glad I could help.   :cheers:
Nakune:
Aight, hopefully a last question. The A button on my controller came unsoldered and took the contact with it, so I went ahead and hacked a second controller for the set-up. Because it's a Madcatz, I made sure to check that it worked before I opened it up (it did). After hacking it, I found that neither A nor X work at all, and the power/guide button is on the fritz, even when the button is not plugged in at all. I checked with a multi-meter, and the signal is coming through fine on the A and X buttons and they are both grounded. Additionally, all are set to NO. Anyone have any clue what's going on? It was suggested by someone else that there was possibly a short, and if anyone thinks they could help actually spot it, I could post a picture of the pad up. Thanks.
wilsman00:
Hello I just built my fight stick and I am having some issues with the joystick.
I have a JLF-TP-8T joystick and I am using this 360 controller:
http://www.joystickvault.com/showpho...to=451&cat=507
All the buttons work fine but only up and right works on it. Down gives me up and Left gives me left but it gives me LBumper at the same time. I can't see any solder issues so far.
Also I tried using the 2 universal dpad grounds to the sticks single and it went all crazy so now I have a +/- for each direction soldered directly to the pcb.
Any help would be greatly appreciated.
HaRuMaN:
Which controller are you using?  Your link is broken.
Also, post some close up pics of your PCB and your soldering.
wilsman00:
Sorry about the link, this should work.  It's the gamestop branded BB-070
http://joystickvault.com/data/507/medium/bb070wiredfront.jpg
http://joystickvault.com/data/507/medium/bb070wiredrear.jpg
Pics to come shortly.
Navigation
Message Index
Next page
Previous page
Go to full version
