Main > Main Forum
New Product: NovaGem CDR - Coin Drop Replacement Pushbutton
Pages: << < (13/13)
mercury187:
How would I power these if using an xbox1 and a MC Cthulu? I also have a Zotac HTPC I might use but I would be unable to use anything but its USB.
BobA:
The Vcc pin of the MC Cthulu will be 5V from the xbox 1 as it is plugged into the xbox controller port which is a modified USB port.   The Coin Drop unit requires 5V and Ground to power the LED.
robneal81:
I have a Mortal Kombat arcade machine and I'd like to turn the coin slots into push-buttons.  Would this be a good replacement?
BobA:
They are not a bolt in replacement but with a little work they can be made to look as if they are part of the coin door.  Lots of examples of how they are used on real coin doors in this thread.   There is a template on the Groovy Game Gear site that will give you the exact measurement of the button and the hole required to mount it.
charleslam:
i saw these before my arcade died from a hdd crash.  i knew i needed to get these back then.  i moved out of my dad's place and have since gotten into a better financial situation.
I have been searching for these for 2 weeks solid via google.  these will be mine.
Since i want to be able to power down softly the machine, and not have the hdd die on me again, i've sent a request to see if instead of "push to reject" i can get a set that say power and reset.  i do not have the patience to use smart strips and set up that configuration.  these buttons will do great if they can sit in my traditional coin drop mounts.  if not i will mod them to fit.
if changing the text is not possible, i guess the next best question would be, can these be opened up to remove the graphic and create my own?
I hope to purchase your products very soon regardless of the outcome.
Pages: << < (13/13)
Go to full version
