Author Topic: Pac Man Bartop  (Read 9083 times)
Pac Man Bartop
« on: March 06, 2007, 07:12:56 am »
Well, step one is complete.  I've loaded an OS (Windows 98 SE) on an old computer and got it up and running again.  I'm actually posting using it.
Next thing to get done is load and configure the software on it.  I plon on using Mamewah, Mame, and some sort of script that will automatically launch Mamewah upon start.  Anyone know how to do that?  Also, anyone know how to get Mamewah to work vertically?
I'm doing this for my brother, he's a Pac Man junkie, and I want to get it done before I move to Phoenix in June.
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
Re: Pac Man Bartop
« Reply #1 on: March 06, 2007, 08:22:56 am »
Go to the wiki there is a whole write up on booting directly into mamewah. It is under "how to hide windows". It is actually really easy to do. Just replace explorer.exe with mamewah.exe, but their a lot of other hiding tips and instructions well worth the read!
My old user name was marlborroman13, but I kicked the habit many years ago!
Re: Pac Man Bartop
« Reply #2 on: March 06, 2007, 08:35:03 am »
thanks for the tip...  I should have known to look there first, lol.
Re: Pac Man Bartop
« Reply #3 on: March 06, 2007, 02:29:16 pm »
Well, since Mamewah won't display vertically, I decided to with GameLauncher (found at the wiki).  Very easy to setup, I have it so that when widows starts, it starts.  Now I just have to tweak a few more things software side, and I can start drawing up some plans.  :cheers:
Re: Pac Man Bartop
« Reply #4 on: March 07, 2007, 11:58:16 am »
Finished the monitor frame...  not painted or sanded yet, needed to check the fit.  Have to square off the cut out for the monitor, its not straight.
Re: Pac Man Bartop
« Reply #5 on: March 07, 2007, 11:58:52 am »
Same pic, no flash.
johnperkins21
  • Last login:December 07, 2019, 07:02:34 pm
Re: Pac Man Bartop
« Reply #6 on: March 07, 2007, 01:11:09 pm »
Are you de-casing that HP? Otherwise, that will be one BIG bartop.
Bob Dole likes cheese.
Re: Pac Man Bartop
« Reply #7 on: March 07, 2007, 02:15:02 pm »
Yeah, I am...  gonna strip it to the motherboard, hard drive, and power supply.
Re: Pac Man Bartop
« Reply #8 on: March 07, 2007, 02:18:51 pm »
frame painted
kizer
    • Links4jeeps.com
Re: Pac Man Bartop
« Reply #9 on: March 07, 2007, 02:54:26 pm »
Looks really nice painted black.
IG-88
Re: Pac Man Bartop
« Reply #10 on: March 08, 2007, 08:39:10 pm »
I've been playing with G.L. a little too. I love it's simple look. I figured out how to modify the game names to whatever you want (pretty good for my lame --I'm attempting to get by the auto-censor and should be beaten after I re-read the rules--) if you want to know.
1 question. How did you get it to go vertical?
-HarumaN
Re: Pac Man Bartop
« Reply #11 on: March 08, 2007, 09:32:19 pm »
In the game launcher config file, there is an option to display vertically.  You can open the file with notepad and change it.  How do you change the game names?
Re: Pac Man Bartop
« Reply #12 on: March 09, 2007, 06:23:53 am »
TY
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
Re: Pac Man Bartop
« Reply #13 on: March 09, 2007, 11:52:24 am »
you change the name in the parenthesise in the map file
like this
pacman "chompchomp"
IG-88
Re: Pac Man Bartop
« Reply #14 on: March 09, 2007, 10:25:08 pm »
Thats right.... ;)
-HarumaN
IG-88
Re: Pac Man Bartop
« Reply #15 on: March 10, 2007, 03:06:05 pm »
OK. I must be missing something obvious here. I got GL to change its list to vertical. Now how do you get the games to go vertical also?
-HarumaN
IG-88
Re: Pac Man Bartop
« Reply #16 on: March 10, 2007, 03:56:58 pm »
Figured it out. Now does anyone know how to stretch the image of the game to fill the entire screen?
I just realized I hi-jacked your post HarumaN, sorry 'bout that.
-HarumaN
Re: Pac Man Bartop
« Reply #17 on: March 11, 2007, 04:31:52 pm »
This is how I do it... from the mame.ini file:
### Mame CORE video options ###
norotate                0
ror                     0
rol                     0
autoror                 0
autorol                 1
IG-88
Re: Pac Man Bartop
« Reply #18 on: March 11, 2007, 07:15:17 pm »
Yup. Thats what I did too. By the way does your set-up have a little log-on mame screen? Now I'm trying to figure out how to rotate that....
-HarumaN
Re: Pac Man Bartop
« Reply #19 on: April 06, 2007, 02:22:51 pm »
I'm following this, about to embark on my first bartops soon.  Keep us posted as you construct the cab.   :)
Re: Pac Man Bartop
« Reply #20 on: May 08, 2007, 04:49:42 pm »
progress pic.  I hope to have this thing completed by Friday.
Re: Pac Man Bartop
« Reply #21 on: May 09, 2007, 06:50:55 pm »
marquee goodness... although the blue looks washed out in this photo, but it really is quite blue.
theCoder
Re: Pac Man Bartop
« Reply #22 on: May 10, 2007, 12:53:42 am »
A big fat strip of duct tape from the inside, along the edge of the marquee will keep the light from "leaking out".  Great progress.
Re: Pac Man Bartop
« Reply #23 on: May 10, 2007, 06:28:44 am »
Good idea.  That leak isn't visible with the lights on, but definately is clear with lights out.  The marquee is actually a piece of metal with Pac-Man cut out of it.  I took a piece of clear acrylic, sanded both sides, and placed that behid the punched out letters.  If gives off a nice blue glow.  I used a cold cathode tube to supply the light.
Heres another pic with the flash on.  I should have this done today, as long as it doesn't rain.
Re: Pac Man Bartop
« Reply #24 on: May 10, 2007, 10:53:58 am »
ghostie in progress:
