Author Topic: CP Plexi Suggestions?  (Read 1214 times)
urbecrisch
  • Last login:January 06, 2024, 08:05:57 pm
  • I was the S**T back in '82
« on: March 04, 2007, 06:38:40 pm »
I'm working on my first CP and I'm not sure what thickness of plexi  Ishould cover the CP with.  Originally  Iwas going to use 1/2" MDF with 1/4" plexi but now I'm wondering if I should use 5/8" MDF with 1/8" plexi.  What have some of you used for your plexi CP?  Are there any pros/cons to using the different thicknesses I mentioned?
AtomSmasher
    • Atomic-Train
Re: CP Plexi Suggestions?
« Reply #1 on: March 04, 2007, 07:10:19 pm »
5/8" MDF with 1/8" plexi is probably the most commonly used sizes and is what I used for the two cabs I built.
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #2 on: March 04, 2007, 07:27:31 pm »
1/8" is standard, but I prefer 1/4". The deep look just can't be achived with anything thinner.
The cons of 1/4" would be that it's more expensive and you might find it harder to work with.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
urbecrisch
« Reply #3 on: March 04, 2007, 07:40:40 pm »
I already have the 1/2" MDF 2x4.  I couldn't find 5/8" MDF anything other than a 4x8 piece which was way too big for what I needed.  I guess I'll have to go with 1/4" plexi.  If I use a laminate router piece I should be able to cut the plexi pretty easy, right?  Also, will drilling holes through 1/4" plexi be tough?
Tahnok
    • Table Arcades
« Reply #4 on: March 05, 2007, 01:28:53 am »
I try to avoid drilling too  many holes in plexi. I drill the wood CP first, and then use a plunge bit followed by a pattern bit in the router to get the button and joystick holes in the plexi. Smaller holes can be drilled using a drill running in reverse and melting through.
urbecrisch
« Reply #5 on: March 05, 2007, 01:41:07 am »
Wood CP is already cut so I was thinking all I needed was to clamp the wood CP on top of the plexi like a template and start drilling into the plexi.  What your saying is the plexi is too fragile for a 1 1/8" drill bit?
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #6 on: March 05, 2007, 02:18:36 am »
Hell Yes!!!   Don't even think about using a 1 1/8 inch drill on it unless you want huge cracks in it.
Do what Tahnok said and use a plunge router bit on it followed by a flush trimmer bit, following the holes you already cut in your wood panel.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
acevedor2
  • Last login:January 22, 2022, 07:44:45 pm
« Reply #7 on: March 05, 2007, 06:40:20 am »
I didn't have a plunge router so the option I chise was to use a 3/4" spade bit to drill a hole wide enough the get the pattern router bit through and then routed the rest of the hole out.  It took an extra step but went very quickly actually - and most importantly, zero cracks!  :)
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
ahofle
    • Arcade Ambience Project
« Reply #8 on: March 05, 2007, 11:32:25 am »
Here's a tip if you must use a drill bit on plexi...  DO NOT push down too hard or you will crack the plexi as Fozzy said.  Put the drill on the fastest setting, use light pressure and start drilling.  Let the plexi start melting and then increase the downward force slightly.  Once you get the hang of it, it's actually quite easy.
