Author Topic: What FE has fastest navigation?  (Read 1209 times)
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« on: March 03, 2007, 08:43:53 pm »
Almost embarrassed to admit this, but I've kept MAME32 with its cheesy looking Windows interface on my horizontal cab for nearly 2 years because of how quickly it can  move through the ROMs list with the trackball by grabbing the slider and scrolling down.
I really like MaLa on my vert cab, but keep a limited number of ROMs on there.
It makes me want to put a better looking front end on my horizontal cab, but I keep all ROMs loaded on there in case I just feel like messing around and playing something new. Is there a front end that offers trackball navigation that is as quick as MAME32?
loadman
  • Last login:August 17, 2020, 03:23:55 am
    • MaLa
Re: What FE has fastest navigation?
« Reply #1 on: March 03, 2007, 09:34:05 pm »
So are you saying you are having trouble with Trackball use with MaLa or it working but it is too slow on your system at the moment?
TOK
« Reply #2 on: March 03, 2007, 10:33:19 pm »
The cab I have MaLa on is a vert cab I set up mainly for shooters, so it's just two sticks/3 buttons. The cab I need the front end for has a trackball. At the moment, it only has MAME32 on it.
MaLa navigation is a bit slow with the sticks for a large amount of games. I didn't realize it'd be faster with the ball, but that's what I'm trying to learn without going through and trying all of them.
Havok
  • Trade Count: (+17)
« Reply #3 on: March 03, 2007, 11:10:49 pm »
AtomicFE has a new Turbo Browse option, and also you can search for a game by pressing F1 (redefinable) if you know the name...
loadman
    • MaLa
« Reply #4 on: March 04, 2007, 12:25:35 am »
Really  ???
There are options to make it the speed you want, Plus you can set up you stick to skip page of events etc
have a play and ask if you are having troubles
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #5 on: March 04, 2007, 05:45:51 am »
AtomicFE supports trackball too.
Bobbler
  • Last login:July 15, 2016, 11:33:30 am
« Reply #6 on: March 04, 2007, 12:14:57 pm »
Something that annoys me a little with GameEx personally. The list is a bit slow to scroll through even with using the page down "shift". I originally had my spinner hooked up to the Z-axis but its still no different than moving with a joystick UP and Down. Would be nice if it had either an analogue mode for spinners or a quick search popup so that if you held down the direction it would come up with the starting letter after a short time. Anyone who has used a Sony HD5 MP3 player would know what I mean here...hard to explain in words.
TOK
« Reply #7 on: March 04, 2007, 12:38:17 pm »
Really  ???
This sounds like it might work for me. Since I have about 60 games on the vert machine, I've always just used the default with the stick where it scrolls slow, then faster if you hold. Still not fast enough to jump through a couple thousand ROMs.
Is there an option where you can do something like make the player two stick jump down by letter of the alphabet? Any type of thing similar to that?
TOK
« Reply #8 on: March 04, 2007, 12:39:44 pm »
Thanks Youki. All of the front ends are so good now that it's very difficult to decide what features matter the most! I'll have a look at Atomic.  :cheers:
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #9 on: March 04, 2007, 01:06:30 pm »
Yes, have a look on the controller tab in the options dialog. Letter up and down.
Follow the link to get a full explanation on how to setup your controllers.
http://mala.arcadezentrum.com/controllerconfig.html
If you use the MaLa 'shift' key you can do the following with one stick for example:
stick up and down: 1 game up and down
'shift' + stick up and down: x games up and down (x is definable or can be one page depending on the layout. check the tab controller -> options)
stick left and right: 1 letter up and down
The default MaLa 'shift' key is Player 1 Button 1 (Left Ctrl).
There is also an options on the tab controller -> mouse which enables the 'shift' key with a mouse or trackball to jump x games in the list. This should speed up the scrolling.
« Last Edit: March 04, 2007, 01:24:28 pm by swindus »
