Author Topic: HUGE Harbor Freight Sale from 3/2 - 2/05 (It's a Hardware Store...haha)  (Read 1934 times)
sonudasouf
  • Last login:April 16, 2021, 02:20:12 pm
Hey Guys, there's a HUGE Sale going on at Harbor Freight Right now...To name a few,
ELECTRONIC FLYSWATTER - $2.99
60 Pc Terminal Bit Set - $1.50
Magnetic Leveler - 2 for $1.00
Rotary Tools Set - $5.99
HEavy Duty Work Gloves - 99 Cents
Rubber Coated Grip Gloves - 99 cents
Putty Knife Set - $3.99
Wire Strippers - 99 cents
4 pc Spade drill set  - $1.99
Right Angle Screwdriver - $2.99
100 REUSABLE Cable Ties - 99 Cents
4 pc Bar Clamp/Spreader Set - $5.99
250 PSI Air Compressor - $5.99
56 pc Knife Set - $7.99
150 Watt Soldering Gun - $7.99
There's also ALOT More on sale, and a whole other ad, along with a coupon book at the stores...So check them out!!!
Anyways, check it out, here's the link:
http://www.harborfreightusa.com/usa/tabviewer/startBrowseBook.do?bookid=162&preview=&type=RET&simple=
« Last Edit: March 03, 2007, 03:02:39 am by sonudasouf »
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
How could you fail to mention the electronic flyswatter for only $2.99???!!!
LOL!
Thanks for the heads up!
Xam
Can't talk to a psycho like a normal human being.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
You should post this over in the woodworking forum.
And that electronic flyswatter rocks.  :notworthy: :cheers:
It's 9am. I'm calling it a nite.
sonudasouf
Haha, yeah, The flyswatter is pretty Freakin awesome...I got back with spending Just over $60, But I got ALOT of decent stuff...
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
I don't understand the relevance of the air compressor...Can you actually use that small air compressor to paint your cab??
Some awesome deals on here, for sure...
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
sonudasouf
Well, I got it thinking of doing the same thing, and considering they also had an airbrush set for like $6, the whole setup for under $15 seemed like a steal...Well it turns out though I couldn't finad an adapter to fit between the airbrush kit and compressor, and the compressor comes with some plastic tips to blow up inflatable things, It didn't fit with the airbrush...I still got both, but hopefully we can find an adapter to work on it...
