Author Topic: How do I make square holes for bolts in metal control panel?  (Read 1875 times)
rackoon
  • Last login:July 28, 2023, 02:29:36 pm
  • I EAT PENCILS!
Like the title says I need to make square holes in my metal CP so my bolts holding my joystick wont spin when I tighten them. I was hoping to use black bolts with no screw driver notch on them. Should I try a file or may by a carbid blade in my jig saw.
So how is every one else solving this? :dizzy:
They treated me like an animal and that's what I became.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: How do I make square holes for bolts in metal control panel?
« Reply #1 on: March 02, 2007, 04:56:56 pm »
Drill a hole then file it out square with a square needle file..... It's really quick and easy to do. Try it.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: March 02, 2007, 06:07:47 pm »
Drill a hole and file it out. That's how I have always done it.
« Reply #3 on: March 02, 2007, 06:23:17 pm »
I recommend Kens method.
I do not recommend Fozzys method.
Fozzy The Bear
« Reply #4 on: March 02, 2007, 06:36:28 pm »
:dizzy::laugh2: :laugh2:
ROFL What is this Lew.... "National Confuse a Newbee Day" LOL  ;D
Best Regards,
ahofle
    • Arcade Ambience Project
« Reply #5 on: March 02, 2007, 06:56:26 pm »
 :laugh2: :laugh2:
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
« Reply #6 on: March 02, 2007, 07:13:24 pm »
Both Ken and Fozzy are NUTS!  Much much too hard to use either of their method!  I have found the best way to do what you are asking is to simply drill a hole and use a square file to file it out.   Cleanest way to do it by far!   ;D
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« Reply #7 on: March 02, 2007, 07:33:40 pm »
Your all nuts ! He needs to go to lowes and get a square drill bit. ;D
johnm160
  • Last login:April 09, 2024, 09:00:46 pm
« Reply #8 on: March 02, 2007, 07:45:24 pm »
A square router bit is much faster and cleaner.  ;D
FrizzleFried
    • Idaho Garagecade
« Reply #9 on: March 02, 2007, 08:12:17 pm »
Blow torch?
Fozzy The Bear
« Reply #10 on: March 02, 2007, 08:24:27 pm »
OK OK I take back my first answer......
The best way to cut these holes is with a "thermal lance" This is a high pressure gas plasma cutter cooled by liquid nitrogen on the end of a 12 foot pole designed for cutting through up to 4" plate steel.... Favoured by large scale safe crackers.  Works like a dream. Even cuts great trackball holes. ;)
Anyway!!! Who says the hole wants to be square... It's Like So Uncool to be square Dady'o...
Best Regards,
« Last Edit: March 02, 2007, 08:27:03 pm by Fozzy The Bear »
johnm160
« Reply #11 on: March 02, 2007, 08:27:27 pm »
Can I get a cheap one at Harbor Freight?
rackoon
  • I EAT PENCILS!
« Reply #12 on: March 02, 2007, 08:41:29 pm »
I had a feeling you guys were going to say that. :banghead:
So off to Home Depot it is, to buy a square drill bit  :angry:
johnm160
« Reply #13 on: March 02, 2007, 09:00:34 pm »
Good Choice ;D
shardian
« Reply #14 on: March 02, 2007, 09:24:26 pm »
Just use your teeth like normal people. Don't listen to these yahoos.
SirPeale
  • Green Mountain Man
« Reply #15 on: March 03, 2007, 07:33:24 am »
Teeth are jewels, not tools.
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #16 on: March 03, 2007, 08:22:29 am »
Easy.  Square hole punch.  They have 'em at Staples.   :)
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
bfauska
  • Last login:May 06, 2024, 02:41:27 pm
« Reply #17 on: March 03, 2007, 01:59:55 pm »
This thread is cracking me up, but on a serious note... If you don't want to file your round holes square (which as we've heard several times is the wrong way), or you don't want to start with round holes and make them square with a file (also clearly wrong) you could use a square hole Punch as suggested by Hypernova, only problem there is his source doesn't provide stout enough punches.
We use Greenlee punches at work for our square holes in steel needs, and I think I have seen people discuss similar products for getting a button sized hole (round) into a metal CP also.  You can use them with just the punch and a wrench.
WARNING, this is a rather large PDF of the catalog, if your not interested in the punch I wouldn't wast the time or bandwidth.
http://www.greenlee.com/cat_docs/Holemaking_07.pdf
Enough serious suggestions, has anybody tried cutting a round hole and filing it?
Later,
Brian
« Last Edit: March 03, 2007, 03:25:35 pm by bfauska »
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #18 on: March 03, 2007, 09:12:17 pm »
If you make a hole all the way through the control panel big enough for the end of the bolt to fit through, won't the bolt just fall right through?
