Author Topic: Please Help...Mag Stick Plus Config  (Read 1263 times)
cornishHen
  • Last login:February 08, 2016, 08:32:23 pm
« on: February 28, 2007, 09:26:24 pm »
I am finishing assembly of my cab, and I ran into a bit of a problem.. The plastic acuator that touches the switches in the joystick pops down below the switches.. I am thinking I may have put the plastic piece that holds the BIG spring on the top of the joystick upside down. Can someone confirm the correct configuration A or B ?
http://s104.photobucket.com/albums/m180/cornishhen/arcade/
TIA! --Preston
Encryptor
  • Trade Count: (+34)
Re: Please Help...Mag Stick Plus Config
« Reply #1 on: February 28, 2007, 10:18:50 pm »
Maybe this will help you tell if you have it together wrong.
Encryptor
cornishHen
« Reply #2 on: February 28, 2007, 10:49:58 pm »
Thanks Encryptor...That was helpful..borderline worthless.
I've added some pictures of my project to the same link from above..
Encryptor
« Reply #3 on: February 28, 2007, 10:57:01 pm »
The review on Retroblast where they take the stick completely apart and show how it goes back together is borderline worthless? What to hell are you looking for then?
Encryptor
cornishHen
« Reply #4 on: February 28, 2007, 10:59:53 pm »
there was no link in your reply....review it.   sorry i thought it was a bad joke. no harm.
Encryptor
« Reply #5 on: February 28, 2007, 11:01:44 pm »
Did you get the PM I sent you? No harm.
Try this if you didn't get it in the PM.
http://www.retroblast.com/reviews/joysticks/ultimarc_magstikplus_part1.html
Encryptor
cornishHen
« Reply #6 on: February 28, 2007, 11:15:02 pm »
Thanks encryptor...no didn't get pm.   I think link answers my question.   I didn't won't to pull my tron stick off without
knowing for sure.. i have tons of pics i plan to post when this beast is done..   eventually it will be at www.novacade.com.
So far the plans are as follows:
Custom Fractal Generated Graphics  - done
EL Panel lit logo on control panel - done
Modded flightsick to Tron style with EL Glow wire - done
Custom LED starburst panels in the portholes on the arcade sides( 100+ leds + ledwiz controlled) - done ..not mounted
Fog machine - bought it and working on routing flow - possible fire hazard..so the cab may have a built in fire extinguisher!
20 X 4 LCD parallel port mod -  not working..yet
!!!!Mala!!!!!
Thanks again..didn't mean to sound ill.. later - pzappa
cornishHen
« Reply #7 on: February 28, 2007, 11:20:10 pm »
one more spec.. i feel like i'm announcing a secret project.  fun!
TopGun Light Gun with american laser games - done tested and works well.. Mad dog Mcree is fun.
pZ
Encryptor
« Reply #8 on: March 01, 2007, 05:43:45 am »
You should post a link in the project announcement forum when you're ready.
Encryptor
