Author Topic: [AtomicFE] [updated 03/11!]Patch for Atomic 0.19 online  (Read 1201 times)
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
« on: February 28, 2007, 10:54:04 am »
Hi,
I put a patch for Atomic 0.19 on line on my website.
It fixed 2 littles bugs in ATomicManager  and AtomicKeys.
« Last Edit: March 11, 2007, 05:31:44 pm by youki »
youki
    • Atomic Front End
Re: [AtomicFE] Patch for Atomic 0.19 online
« Reply #1 on: March 03, 2007, 09:03:44 am »
I have just updated this patch on my website.
I fixed a little bug in LedWizManager.
youki
    • Atomic Front End
Re: [AtomicFE] [updated 03/04!)Patch for Atomic 0.19 online
« Reply #2 on: March 04, 2007, 12:13:00 pm »
Patch updated again..sorry.
It fix now, a big performance problem in the page jump by letter options.
youki
    • Atomic Front End
« Reply #3 on: March 05, 2007, 04:18:08 pm »
Again...a new update of the patch on my website.
It fix a problem on the "live" filter dialog.
youki
    • Atomic Front End
Re: [AtomicFE] [updated 03/05!]Patch for Atomic 0.19 online
« Reply #4 on: March 11, 2007, 05:31:30 pm »
New update of the patch.
bug corrected on LEDWIZ Support.
bfauska
  • Last login:Yesterday at 02:41:27 pm
Re: [AtomicFE] [updated 03/11!]Patch for Atomic 0.19 online
« Reply #5 on: March 11, 2007, 07:37:37 pm »
What are the chances of adding joystick/gamepad control natively.   I use a gpwiz and the only thing that would require me to use joy2key right now is the frontend.  I haven't played around on it in a while, but I seem to remember that the joystick works but not buttons, how hard would it be to add support for 28 buttons w/ the joystick?
It seems like a great product and if it's a pain to change the interface, I may just breakdown and use joy2key.
Later,
Brian
youki
    • Atomic Front End
« Reply #6 on: March 11, 2007, 08:16:22 pm »
I plan to implement joystick/gamepad support nativly in a near future. But for now, my problem is that i don't have usb joystick to test.
But  for  now , joy2key works very well.
bfauska
« Reply #7 on: March 12, 2007, 02:39:37 am »
Cool, since it won't be in the TOO near future that I actually build a cab, I suppose I may get lucky with the timing.  If I build a cab before you get a chance to add the feature I guess I'll just have to use joy2key.  I just found out I may have to anyway.  My NES emu only supports button 1-18 or 20 on the joystick (which means I run out with my current setup and player 2) and my SNES doesn't allow anything but the "Joystick" part of the input to control direction (so the buttons on my GPwiz hooked to p2's joystick won't work)
Thanks for the response, I look forward to seeing you FE in my cab one day.
Brian
