Author Topic: Replacing spinner on a Slikstik classic with a GGG spinner?  (Read 1943 times)
Shoegazer
  • Last login:May 10, 2015, 10:37:58 am
    • NonMAME - The ultimate site for the OTHER arcade emulators!
« on: February 24, 2007, 09:44:25 am »
Is this possible?  I understand the mountings on the GGG spinner match the standard Happ button mounts, but I'd really like to take one of these Groovy gears for a spin.  (groan all you want, I thought that was pretty clever).  ;)
Shoegazer
NonMAME: Your best source for the OTHER arcade emulators!
http://nonmame.retrogames.com
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
Re: Replacing spinner on a Slikstik classic with a GGG spinner?
« Reply #1 on: February 24, 2007, 10:20:50 am »
With a little modification you could attach a beer tap to your slickstick control panel... :cheers:
...OF COURSE you can modify your panel to accept anything you want!   Drop out the SickSlick spinner,  cut the hole to standard button size,  drop in the turbo twist 2 (with IT's optical board)... attach to PC...Vrooooom!
Now...that said...I have to ask...unless you are having problems with your SlickSuck spinner,  why mess around with it?   You have already made it through the tough part with SuckSuck...that is GETTING the product.   By pretty much all accounts,  once you GET the product,  you are golden,  the SlickPrick products are quality.
« Last Edit: February 24, 2007, 05:29:57 pm by FrizzleFried »
Shoegazer
« Reply #2 on: February 24, 2007, 03:33:57 pm »
Thanks for the tips, yeah I'm a little green at the DIY stuff (though that is changing, slowly) but what you're saying makes perfect sense.  I thought the GGG hole was actually SMALLER than the hole made for the SlikStik spinner (since I have yet to take the chassis off of the panel), but I see what you're saying now.
I'd be interested in replacing what I have due to the higher resolution on the GGG spinner plus all the great extras (steering wheel being one) that are just not possible with the original SlikStik classic spinner.
Shoegazer
« Last Edit: February 24, 2007, 03:36:11 pm by Shoegazer »
BobA
  • What Me Worry?
« Reply #3 on: February 24, 2007, 04:03:10 pm »
The GGG hole is 1 1/8 inch and the Tornado has a 1/4 inch hole.  The GGG takes a much bigger hole.  The mounting bracket on the Tornado is under the CP and only the shaft stick thru.
millercentral
  • Last login:March 07, 2024, 04:38:47 pm
« Reply #4 on: February 24, 2007, 08:08:10 pm »
I did this by using a step-bit drill bit to enlarge the hole to accomodate the GGG spinner. Worked great. I just plugged the other mounting holes with carriage bolts and everything looks great.
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
« Reply #5 on: February 24, 2007, 11:04:17 pm »
interesting. i think i've seen these, but never used one. did one bit get you all the way from 1/4" to 1 1/8"? how well-centered was the final hole relative to the original? where would i get one of these bits?
thanks.
to see my "Frankenpanel" and design notes, click here.
millercentral
« Reply #6 on: February 24, 2007, 11:29:34 pm »
This is the one I used:
http://www.amazon.com/IRWIN-10235-UNIBIT-4-Inch-8-Inch/dp/B0009XJ31A
I was drilling into a metal, powdercoated panel -- a stressful experience -- my initial spinner hole was 3/8". The process took about 2 minutes, made a lot of metal shavings, but the hole was perfectly clean at the end (I did file the inside of the hole a bit to remove a couple of burrs) -- with the spinner in place it looks perfect.
One of these days I'll get around to doing a project post and show the pictures and the rest of the details...
FrizzleFried
    • Idaho Garagecade
« Reply #7 on: February 25, 2007, 02:31:14 am »
A hole saw works just as well and costs about half (or less) as much.   Just use the drill bit to "guide" you in to the existing hole and saw away.
I've done it on wood and metal...
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #8 on: February 25, 2007, 03:08:19 am »
I have been thinking of doing this switch also, my friend got the GGG spinner and arkanoid finally played great.
My Websites
RobotronNut
« Reply #9 on: February 25, 2007, 11:32:24 am »
I was drilling into a metal, powdercoated panel ...
doesn't look like it would work with a wood panel; the wood would be too thick. a hole saw, as suggested by FrizzleFried, is probably a better solution in wood.
shorthair
« Reply #10 on: February 25, 2007, 02:35:55 pm »
I'd think a hole saw would be a lot quicker and cleaner.
