Author Topic: Please help me indentified what I'm missing inside my CPS-2 Cabinet (pictures)  (Read 2071 times)
snk
  • Last login:September 20, 2023, 11:19:20 pm
Hello
I just bought a cabinet last week end. It has a working 25" monitor, the control panel, the coins mech and the power supply. Other than that, it is empty, meaning there is no game inside.
I understand I have to buy a CPS-2 "A" Board and also a CPS-2 "B" Board, but I have a feeling I'm missing an harness though, could you help me find out what harness I'm missing ? Here are the pictures.
These three connectors are from the control panel. But I don't think it connect directly to a CPS-2 cartridge? :
These two connectors are from the power supply:
Other connectors next to the power supply. Don't know what it could be even though I didn't check it with a multi-meter yet:
This one I believe is for the sound (QSound). Does it connect directly to a CPS-2 Cartridge ? I don't know:
Another plug, next to the monitor isolation transformer.
This one, I know, it's a harness from the monitor:
finally some harness from above the coin mechs:
I do not think all these plugs connect directly to a CPS-2 cartridge A or B.
My question is: what harness I'm missing so I can plug this harness to all these wires to finally plug all this to a CPS-2 game ?
Thanks for your help ! :)
This's what makes a legend
BobA
  • What Me Worry?
You are missing the jamma connector that hooks the joystick power buttons etc to the CPS2 board.   If you trace the wires from the different molex connectors do some go to the control panel?   It look like you have the aux kick harness that goes right to the CPS2 but not the jamma.  You have way too many molex connectors to guess at.  Try tracing some of them to see where they go, some are probably coin door power etc.
The CPS 2 pic shows where the jamma harness connects as well as the kick harness (thin white connector)
BobA
« Last Edit: February 22, 2007, 03:24:08 pm by BobA »
Crowquill
  • Last login:December 03, 2021, 05:02:15 pm
I'd suggest you start by downloading a couple manuals for CPS-2 games. Maybe Super Street Fighter, the Street Fighter Alpha games, Darkstalkers, Vampire Savior, or Marvel vs. Capcom. All of these are 6-button games that will use the same wiring. Download them here:
http://arcarc.xmission.com/
While you're there you might download a Street Fighter II manual as well.
Like BobA said, you're first going to have to start with a JAMMA harness. This'll connect power, video, control panel (joys, start, and punch buttons), and the coin door and switches near it to the A Board. It looks like they used the plastic molex connectors to make servicing simple on the original harness. You can add these molex connectors to the JAMMA harness you get or just cut off the connectors and hook the harness directly to the switches or wiring. The stereo speakers for Q-Sound hook right into the A board.
On CPS-2 games, the kick buttons are wired to a seperate harness. What's a bit weird is that it looks like the flat connector from the control panel is a CPS-1 kick harness. I'm pretty sure those cabinets were only introduced with CPS-2 games, but with this stuff you never know what an operator has done to them. They may have had Street Fighter II (WW, CE, or Turbo) running in it. If you're planning on putting CPS-2 in there, you'll need a CPS-2 "kick harness".
If this is the shape of the cabinet, how do you know everything works (especially the monitor)? Also, if you're going to enter the world of CPS-2 gaming, make sure you read up on "Suicide Batteries".
http://www.arcadecollecting.com/dead/dead.html
There are several sites dedicated to changing the batteries, but I like this guy's approach of using a battery holder.
http://home.online.no/~tjaberg/cps2_battery/index.htm
It's definitely a nice cab to have. Is that an actual marquee that's painted red or just some scrap material? Full-size CPS-2 marquees can be a bit tricky to find. They were usually cut down to fit another cab such as a Dynamo.
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
Picture 2: One plug for player one controls, one plug for player two controls, one "custom" plug for the kick harness
Picture 3: Big plug for your power to the board, small plug for your transformer(?)
Picture 4: Plug to your On/Off switch(?) and power to the marquee(?)
Picture 5: your guess is as good as mine
picture 6: plug from power supply to transformer(?)
Picture 7: you're right
Picture 8: power to coin lights, service buttons, credit switches. (all ?)
In pic #3 & #4 it looks like you can connect the two smaller connections.
None of the wires that you have can be connected directly to the CPS A board.  You would need to get Molex connectors to attach to the harness.  Without actually seeing the machine, those are my best guesses.
My Power supply has two groups (one small, one large) of wires on one side and one group on the other.  The single group goes to my power switch.  Large group goes to the Jamma harness, the other goes to the transformer.
Where are you located?
« Last Edit: February 22, 2007, 11:06:16 pm by Spaz Monkey »
snk
Thanks all for your answer. Now it is crystal clear for me, I need:
  • a CPS-2 A and B cartridge
  • a Jamma harness
  • a CPS-2 kick harness
Trace all the wires down and redo the wiring.  :-\ I was hoping I could find a Capcom Jamma harness with the molex connectors. I guess I'll cut all this and get the soldering iron ! Pff a lot of work... Or where could i but these molex connectors for crimping ?
Crowquill -> I know the monitor works because I actually have a MAME cab and I tried this monitor. It needs a cap kit though. I actually bought this CPS-2 cab to use some parts to finish my MAME cab.  :-\ I'm planning to sell this CPS-2 cab. No it's a marquee that's painted in red, same for the bezel.
Spaz Monkey -> I'm located in the Bay Area, we are close ! Do you wanna come over  ;) Well, just to let you know, I'm selling this cab (don't have the space for it) preferably as is.
fjl
  • Pixels Rule!
Sorry to rag on your new cab but that's a an ugly looking marquee design. And those colors...
Please fix it up.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Please fix it up.
A little premature, aren't we ? He JUST got the cabinet. It's not like he's been sitting around touting eleventy brazillion different earth-shaking designs without any real progress. :banghead:
snk: a GREAT cabinet ... my first upright was a big blue Capcom cab like that and I still love it (even though classics are where my heart lies). You might want to pick up some Molex connectors (try local electronics store or The Real Bob Roberts) and wire to the JAMMA harness using the existing connectors instead of chopping the existing "subharnesses". It's not much more work than wiring from scratch and gives you/uyer more options down the line if you/buyer want to change the cab up.
Cheers
« Last Edit: February 23, 2007, 08:55:45 am by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
Spaz Monkey
Not too sound like a jackass, but if you're going to sell it as is, let the other guy/gal worry about wiring.
knave
  • Last login:October 13, 2023, 03:32:33 pm
I saw the add fro that cab too.  It looks to be in pretty good shape though I wasn't as fond of the high Marquee as opposed to some other cabs.
<snk> I'm just a bit North of you.  Nice to know I'm not the only noob in town. LOL.
Crowquill
That's awesome to know it works. It's hard to find a monitor that DOESN'T need a cap kit. That's a shame about the marquee. There probably isn't any way to get the red off without damaging the plexi underneath. BTW, which game's marquee is it?
The huge marquee on these cabs would be a real problem for conversion. I've seen one where the top of the cab was cut off to make it smaller, another one they were smarter and just blocked off part of the marquee to make it normal sized. If you see these with the full Capcom marquees they are a thing of beauty (mostly due to Capcom's fantastic artwork). Here's a pic of my SF Alpha marquee. I bought it just for the artwork.
fjl
  • Pixels Rule!
Please fix it up.
It's coming along, honestly...  :angel:
snk
Spaz Monkey -> If I sell the cab like this, fine. If not I may fix it up to sell it back. Anyway I like to know extensively what I'm selling and what needs to be done.  :) If I had to keep it for myself, I'd not even bother with the CPS-2 cartridge, I'd do a MAME conversion.
Crowquill -> Ooops, I mean the marquee is just a nice piece of Plexiglas that has been painted red somehow. There is nothing underneath. You're right the size of the marquee may be a problem but I believe is some places like http://www.mamemarquees.com they can print custom to the size you want. And I'm sure they can use their own existing art.
