Main > Main Forum
First Project help please!
Birdtales:
--- Quote from: Scanner on April 07, 2003, 10:42:34 pm ---Yeah the problem has me worried because I bought the system so I could use the monitor. Here are the specs from Wells:
http://www.wellsgardner.com/wellsgardner31/supportdata/K7500.pdf
It is Med Res - but it says it is actually 15kHz so I am back in business. Yes! Now if I can just get it working.
The joysticks are 49 way. Should I have gone with the JPAC? I am creating a new CP to interface directly into the computer.
I think you may be reading the specs wrong. It is medium resolution as stated here...
K7500
MID RESOLUTION
K 7 5 0 0
P R O D U C T S P E C I F I C A T I O N S
Scanner:
I am the one who needs sleep you are right. So I don't think Arcade VGA will work for me after all. Which still leaves me with the monitor problem. Any suggestions guys?
Birdtales:
You need a Standard Resolution monitor. That said I'm pretty sure NFL Blitz 99 won't play on a Standard Res monitor (just a guess though) so you may not be able to "Have your Mame and Blitz it too".
Where are you located? Might want to try an auction. I picked up a dual monitor 25" working Cabinet for 115.00. The two 25" Standard Res monitors were worth that. Not sure if I want to let one go but may consider it.
Scanner:
Blitz worked and worked well for about a week. It stopped working after I moved it a couple of times. This is getting me down. :-[
