Main > Software Forum
command.dat finally updated... after nearly two years.
<< < (2/2)
shock_:
J5 I've definitely heard of, but not played with yet.  So that's good news - I should be able to get command.dat, J5 and MaLa to all play nicely, even without using some mame32 variant that might be a lot of trouble to keep current?!
Coolness
Howard_Casto:
Yeah I externalized support for that very reason.  Keeping up a custom build of mame is a real pain in the butt for anyone, so you can't expect it to be current.  I like just using ahk scripts to get j5 to pop-up in game as it means I can look at things like command.dat and still have vanilla mame even if it just came out yesterday.
FrizzleFried:
...any way to get this to work with command line MAME?
Howard_Casto:
You guys forgot to mention that you've added new command flags.
So far I've found Upper-case "O" or "_O" which I'm assuming is for a hold symbol.
Any others you want to mention, as the author's guide is out of date?
SirPoonga:
--- Quote from: FrizzleFried on February 24, 2007, 11:37:09 am ---...any way to get this to work with command line MAME?
I believe mame plus supports this.
Navigation
Message Index
Previous page
Go to full version
