Main > Main Forum
melamine?
u_rebelscum:
--- Quote from: skirge66 on April 06, 2003, 03:37:04 pm ---a qustion on laminant, how dificult is it to laminate your control panel after all the holes are cut? i would like to have none of the hardware showing on top of the cp which will require things like the trackball etc to be sunk into the wood the laminate over top of the mounting plates.
Be sure to fill the holes and the top of the mounting plate is level with the top of the wood if you want them totally unnoticeable. Otherwise, they might look like bubbles. Not ugly, but not perfect.
Also, if you laminate after you cut the holes, you can route the laminate instead of drill. This can result in cleaner holes if done correctly.
