Poll
Which do you have, like better, or plan to use? Translucent Trackball or Solid Color Trackball?
Translucent Color Trackball
28 (82.4%)
6 (17.6%)
Total Members Voted: 34
Author Topic: Translucent or Solid Color Trackball  (Read 1248 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: February 16, 2007, 01:24:40 pm »
I am going with a translucent blue, but I may or may not plug in the bulb?  I have a bright white LED, but need some way to position it in a vertical posistion under the trackball.  The default setup on it now is a normal bulb in a sideways posistion.
So what would you guys do as far as me setting up one of these superbright LEDs under the trackball where the light will shine upwards instead of the bootleg sideways posistion now.
To make it more understandable.  The socket is sideways I need the socket to be up and down.
moriartyds
  • Last login:November 05, 2007, 09:09:39 pm
Re: Translucent or Solid Color Trackball
« Reply #1 on: February 16, 2007, 01:32:13 pm »
I went with the translucent blue one myself, but I have not compared it directly to the solid one.
I'll probably replace the light bulb with an LED in the future.  Someone on here posted some pictures of a little U shaped cradle made out of wood they used to mount the LED.  I'll see if I can find the thread.
Jeff AMN
    • Gamer Theory
« Reply #2 on: February 16, 2007, 01:34:29 pm »
I'm going with translucent blue in my cab. Even if I couldn't light it, I like the look of the translucent ball a bit better than a solid color one.
moriartyds
« Reply #3 on: February 16, 2007, 01:44:54 pm »
Take a look at this thread for ideas/pictures of mounting an LED under a trackball:
http://forum.arcadecontrols.com/index.php?topic=50298.0
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
« Reply #4 on: February 16, 2007, 05:53:27 pm »
I also run with a translucent blue TB...though it would be BITCHEN to have a CLEAN translucent TB with MULTI COLOR LED's going through the color spectrum!!??
Jeff AMN
    • Gamer Theory
« Reply #5 on: February 16, 2007, 05:55:01 pm »
Knowing my luck, instead of a rainbow spectrum it would combine the colors and form some sort of poo brown.
rdowdy95
  • This is my rifle.
« Reply #6 on: February 16, 2007, 06:02:15 pm »
LOL.  Okay I will have to somehow rig something up and hope it looks cool.  Also though just looking at it, it looks cool.  Like without the light it is a nice blue color.
whammoed
  • Last login:Yesterday at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
« Reply #7 on: February 16, 2007, 08:03:36 pm »
MYX
    • MYX Digital Blog
« Reply #8 on: February 17, 2007, 06:11:38 pm »
I used 3 White LEDs clustered to light my trackball and it looks awesome.
LINK
Now, mine was built before the lightmite came out. I would have probably got one of those. So I second the plug.
Plugged plug.
M    Y    X
Gamester
« Reply #9 on: February 17, 2007, 07:11:01 pm »
shameless plug:
http://www.nicemite.com/LightmiteTB/LightmiteTB.htm
I like the looks of this device, but why is WHITE not one of the LED color choices?  Unless I missed something, Red, Green and Blue are the only choices.  Most translucent balls are colored...  wouldn't it be appropriate to have white as one of the options?  For instance, I'm planning to get a translucent YELLOW ball.  Obviously shining R,G or B through it would turn the color to mud...
whammoed
    • NiceMite
« Reply #10 on: February 17, 2007, 08:02:30 pm »
shameless plug:
The correct color led produces better results.  Whit tends to wash out the color a bit.  I didn't know yellow was an option...I can produce a special version for you if you like with 4 individual yellow leds (since I have them in stock) at 5 volts.  Or you can get the kit and install your own yellow led(s).
moriartyds
« Reply #11 on: February 19, 2007, 01:54:16 pm »
shameless plug:
Looks pretty sweet.  Do you just screw it through the base of the trackball support?
whammoed
    • NiceMite
« Reply #12 on: February 19, 2007, 05:46:12 pm »
shameless plug:
Yep.  Sometimes there is already a hole there for you to use, otherwise just drill one.  (depends on the type of trackball)
