Author Topic: Do I need to get the long shaft for the Ultrastik 360?  (Read 2117 times)
shatter
  • Last login:June 27, 2009, 02:07:12 pm
« on: February 16, 2007, 12:55:34 pm »
Hi,
I am building a control panel using 3/4" ACX plywood and just got two ultrastiks for it with the standard shaft length. It seems a bit short, is it worth going to the 0.4 inch longer shaft or will it play ok as is? Seems like you'll only be able to hold the joysticks with your finger tips instead of grasping with your whole hand.
Opinions on this? An alternative would be to route the underside of the control panel to make the thickness less.
Aurich
  • Last login:September 12, 2021, 01:34:32 am
Re: Do I need to get the long shaft for the Ultrastik 360?
« Reply #1 on: February 16, 2007, 01:10:14 pm »
I like the standard shaft, but I have a metal CP, so yours sounds too short for me.  :dunno
Kaytrim
  • I'm too nice a guy
« Reply #2 on: February 16, 2007, 01:14:36 pm »
Another option is to mount them from the top and recess the mounting plate.
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
« Reply #3 on: February 16, 2007, 02:04:16 pm »
the shorter the shaft, the quicker the engagement, and the higher your scores in many games (all else being equal). i prefer the shortest shaft i can get away with, without chafing my knuckles against the panel. for my fingers, the stock u360 shaft works well with the round ball top in a 3/4" wood panel with no routing. YMMV.
[edit: added qualifications in italics above]
« Last Edit: February 16, 2007, 03:45:05 pm by RobotronNut »
to see my "Frankenpanel" and design notes, click here.
somunny
  • Last login:September 05, 2018, 02:22:25 pm
  • Is it hot in here?
« Reply #4 on: February 16, 2007, 02:06:52 pm »
I need to grow up beacuse I'm finding this discussion quite amusing.
Dmod
  • Last login:July 12, 2012, 06:50:45 pm
« Reply #5 on: February 16, 2007, 02:32:30 pm »
My CP is 5/8" MDF, and I've got the oval top U360s.
I found that routing the underside of my panel to 7/16" thickness was a lot more comfortable.
My Projects:
Suspended Animation Scratch-built Cab
Driveshaft Arcade Seat Platform
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #6 on: February 16, 2007, 02:35:44 pm »
I have the longer shafts in stock if you need
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« Reply #7 on: February 16, 2007, 03:59:25 pm »
I used the longer shafts in 3/4 mdf and I like it.  I mounted them from the bottom, seems perfact to me
I b**ch. People listen!!
divemaster127
« Reply #8 on: February 16, 2007, 04:02:14 pm »
thats what i did the stock shaft at least for my cp were just to short
dm
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #9 on: February 16, 2007, 05:45:56 pm »
Using the longer shaft will increase the throw of the stick, along with increasing the engagement distance.  Perhaps using the circle restrictor along with the longer shaft will offset the greater throw and engagement distance?  How will this compare to using the shorter shaft without the circle restrictor (short + no restrictor vs. long + restrictor)?
If I do not respond to your post in a timely manner, feel free to PM me.
shatter
« Reply #10 on: February 16, 2007, 10:39:00 pm »
Thanks for all the replies. I am going to go ahead and get the longer shafts and use them with the circle restrictor and give it a go.
squirrellydw
« Reply #11 on: February 17, 2007, 12:19:00 am »
thats what  Ihave its perfact and I am drunk........I love rum
Donkey_Kong
    • CNC Machines
« Reply #12 on: February 17, 2007, 01:33:43 am »
 :laugh2:
destructor
« Reply #13 on: February 17, 2007, 04:16:04 am »
Yes, RobotronNut is right.
Use shorter shafts, are very comfortable.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #14 on: February 17, 2007, 04:53:28 am »
I just wish they had thicker shafts and a hole right down the center.  It would be nice to light up the ball.
RobotronNut
« Reply #15 on: February 17, 2007, 01:55:00 pm »
so far, i've only tried the U360 in 4-way mode. may be a while before i can give it a thorough workout in 8-way mode with robotron. judging by my experience with the square restrictor in 4-way mode, i expect that the short shaft AND the circle restrictor will be best for robotron.
btw, the U360 makes a fine 4-way, but if you're looking for a dedicated 4-way, the J-stik is very similar in feel and performance and is MUCH less expensive. (the U360 and J-stik share the same basic mechanism.) the J-stik is my new favorite 4-way.
destructor
« Reply #16 on: February 17, 2007, 02:03:26 pm »
No compare :D Impossible is to U360 without restrictor to play on normal 4/8-way games. Toooooooooo long throw, never mind short or long shaft.
Circle restrictor - excellent for some games. Now I use U360 with circle on Wonder Boy 3 - excellent.
