Main > Main Forum
Wico 2 1/4" Trackballs?
pfriedel:
Yeah, I forgot that they were also Suzo TBs, so when I saw that on Andy's site, I relaxed a bit - even if I can't pull off a mouse hack, there's always an optipac. :)
Rocky:
Here's a tip if you're going to hack a WICO 2 1/4" TB.
I had a real hard time connecting wires to the small red connectors that they provide :P
I discovered that I could use the power connectors off of an old PC power supply (3.5 inch floppy power connectors) and they fit ok onto the pin header. So, I just spliced the wires from my mouse hack to the power connector instead of having to crimp / solder onto the pins >:(
Rocky
