| Main > Main Forum |
| Similar product to poly to put over paint? |
| << < (2/2) |
| Mattiekrome:
--- Quote from: Kaytrim on February 09, 2007, 03:18:40 pm ---While following up on another thread I came across this item. It is expensive but it sounds like just what you are looking for. http://woodcraft.com/family.aspx?familyid=4140 --- End quote --- --- Quote from: That link ---You can actually create “floating” objects in your finish by embedding them between coats. --- End quote --- Wonder how side art would look "floating" between a couple coats of that stuff |
| Kaytrim:
--- Quote from: Mattiekrome on February 09, 2007, 04:56:39 pm --- --- Quote from: Kaytrim on February 09, 2007, 03:18:40 pm ---While following up on another thread I came across this item. It is expensive but it sounds like just what you are looking for. http://woodcraft.com/family.aspx?familyid=4140 --- End quote --- --- Quote from: That link ---You can actually create “floating” objects in your finish by embedding them between coats. --- End quote --- Wonder how side art would look "floating" between a couple coats of that stuff --- End quote --- Think about some of the '3-D effects' you could produce. :o |
| javeryh:
The thing that concerns me is that it is self leveling - applying it to an assembled cabinet might be disasterous but if you had the foresight to prefinish everything I bet you could get amazing results floating the art and whatnot. |
| johnvv:
Javeryh: For MDF painting, I highly recommend you: - sand the MDF while wearing a protective mask - apply a coat of primer (Killz or other are fine). Use oil- base for oil-based paint, water-based for latex paints. Apply via roller or brush, not via spray can. - sand, with mask, using 120+ grit sanding material - apply second coat of primer - sand, with maks, using 220+ grit sanding material. This will get the sides very smooth and protect them against water and moisture. For paint, use quality paint. Go to a real paint store, not Home Depot or Lowe's, and tell them what you are trying to accomplish. A good paint store should be happy to help and sell you a high-quality paint that will self-level and perform well. You may pay a bit more, but it will be worth it. They should be able to tell which application method is best matches your desired results with their paint. Modern latex paints are fine as long as they are high quality. They are much easier to work with than oil-based paints. |
| javeryh:
Thanks johnvv. I pretty much followed your advice on a test panel. I used a foam brush on the last coat of paint to avoid the "orange peel" texture as much as possible. I added poly to the top coat and I'm going to add 3 more coats of it before I'm done. I'll post pics of the results in a few days... |
| Navigation |
| Message Index |
| Previous page |
