Author Topic: IPAC4 help needed  (Read 1050 times)
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
IPAC4 help needed
« on: February 03, 2007, 04:59:01 pm »
I have an IPAC4, but only a two player panel (don't ask).  Everything seemed to be working fine, but some time ago the shift function seems to have stopped working.  I really only use one shifted function, and that function is for ESC (player 1 start and player 2 start).  I brought the IPAC4 up in Notepad and hit Ctrl-Alt-P like it said to do.  For some reason the board thinks player 1 button 8 and player 2 button 8 are pressed and/or shorted.  Funny thing is I don't have anything connected to either of those inputs.  I have unconnected the surrounding connections around those two inputs, but it still reports those two inputs as being pressed/shorted.
Edit: I forgot to mention that I seem to be able to hit 'r' in notepad to reset the IPAC4, but then it says to hit the next button or 'e' to exit and when I hit the e to exit it doesn't exit (unless exit doesn't do what I think it should do).
Advice?
P.S.  What are all of those "blinks" on the LEDs on the IPAC4 when it first powers on?  Is that a clue?
« Last Edit: February 03, 2007, 05:06:21 pm by fatfingers »
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
Re: IPAC4 help needed
« Reply #1 on: February 03, 2007, 06:08:17 pm »
The LED light tells you where to look for a problem.  If it blinks once and then stays one, everything is good.  The number of flashes relates to a particular input.
Check out the details at Ultimarc's site:
http://ultimarc.com/ipac2.html
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« Reply #2 on: February 03, 2007, 06:10:56 pm »
Also you could try using the winipaq and click reprogram maybe it will sort out its input issue by rescanning the board
fatfingers
  • Got UltraStiks?™
« Reply #3 on: February 03, 2007, 08:32:42 pm »
Hmmmph.  Tried WinIPAC as well to no avail.  Then I disconnected all inputs from the board, air dusted it and plugged it back in (no wires attached to it) and it still claims at least 1 switch 8 is shorted or always on (34 blinks).  It seems my board has gone bad on me???
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
mrserv0n
« Reply #4 on: February 03, 2007, 09:51:17 pm »
Hrm, maybe the dude from ultimarc will read this and give you a better answer, or you could try writing them an email at ultimarc.com, Wish I could be more help.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #5 on: February 05, 2007, 11:55:59 am »
I can help indeed, drop me an email. andy@ultimarc.com
