Main > Main Forum
Connection to PC and consoles?
rampy:
--- Quote from: radiator on April 04, 2003, 02:35:00 pm ---i have a question about this...
i plan on having a pc and dreamcast in my cab...for pc, buttons hooked up through my ipac, and for dreamcast the buttons will be directly wired to the pad (hack) - just want to know if this will be ok (no interference), as long as both machines aren't on at the same time?
*m
It's my understanding (as this question has come up before) that it's not a good idea, particularly with the dreamcast... unless you find a way to isolate each control element (i.e. diodes or switch(es), or to plugin/activate only one at a time or something)
*shrug* ymmv
rampy
JamesMolloy:
Hrm.. complicated. I thought I'd be able to get connectors to plug into an iPAC. Maybe they'll come up with something like that in time. The X-arcade PCB can handle it so it's obviously possible. I'm just not wild about going down that route because they charge alot for simple connectors and crap controls.
OK, so I can build a control pannel from hacked PS pads and buy connectors to hook to PC or DC. Lucky I have a friend who knows something about wiring.
rampy:
--- Quote from: JamesMolloy on April 04, 2003, 05:23:18 pm ---Hrm.. complicated. I thought I'd be able to get connectors to plug into an iPAC. Maybe they'll come up with something like that in time. The X-arcade PCB can handle it so it's obviously possible. I'm just not wild about going down that route because they charge alot for simple connectors and crap controls.
Well it's not *that* expensive... you can get the pcb separate y'know... if you aren't savvy with a soldering iron you can pay a smal premium for a ready made solution... (although the switching part would still need to be manual, regardless)
*Shrug* good luck, though!
rampy
radiator:
has anyone out there actually done this (PC and DC in same cab) and got it to work well?
if anyone can give me any tips that'd be great
*m
