Author Topic: Frontends  (Read 3315 times)
scoddie007
  • Last login:March 08, 2012, 09:29:58 pm
Frontends
« on: January 31, 2007, 06:31:29 pm »
I was wondering what frontend to use perferably and easy one , and is there any that support zip files?
Thanks.
spacies
Re: Frontends
« Reply #1 on: January 31, 2007, 06:43:48 pm »
MAME32 is the easiest as its all-in-one.
That will get you up and running in no time.
As for a dedicated front end and MAME, then MALA would be the next choice.
I use MAMEWAH, but some say its hard to set up.
The zip files you ask about? Are they your roms?
Leave those zipped and place them on your rom folder.
ahofle
    • Arcade Ambience Project
Re: Frontends
« Reply #2 on: January 31, 2007, 07:09:39 pm »
I personally find it irritating that frontends don't support zipped up snaps/controlpanels/marquees (I assume that's what he was referring to?).
spacies
Re: Frontends
« Reply #4 on: January 31, 2007, 07:21:18 pm »
Oh yeah, what he said ^^^
Gamester
Re: Frontends
« Reply #5 on: January 31, 2007, 09:16:07 pm »
Actually, I believe MAME32 does support zipped snaps/CPs/MQs...
Unfortunately, my preferred FE (MaLa) does not...
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
btp2k2
  • Last login:March 16, 2011, 01:02:36 pm
Re: Frontends
« Reply #7 on: February 01, 2007, 01:09:15 am »
I like Maximus Arcade.
I use it on my cabinets and it is really easy to setup and has a wide array of different emulators supported. I also like it cause it has a MP3 jukebox mode and supports batch files, so I can write a batch file to run a regular PC game from the front end on the cabinet. Kinda fin playing GTA San Andreas on an arcade cab
ahofle
Re: Frontends
« Reply #8 on: February 01, 2007, 01:16:58 am »
Yeah MAME32 does, but it's not really an arcade cabinet friendly FE.  I still use it though.  :-\  I also like using my trackball as a mouse to select games and quickly scroll through the games list.  I can't stand using the joystick and waiting 5 minutes to scroll to a particular game.
spacies
Re: Frontends
« Reply #9 on: February 01, 2007, 02:36:59 am »
Thats why I use MAMEWAH.
Left and right on the joystick takes you to the next or previous letter in the alphabet or press start 2 and find a game.
Easy as pie!
loadman
  • Last login:August 17, 2020, 03:23:55 am
    • MaLa
Re: Frontends
« Reply #10 on: February 01, 2007, 03:15:56 am »
Easy as pie!
That feature is avail in many other FE's too
Try some...  :-)
spacies
Re: Frontends
« Reply #11 on: February 01, 2007, 03:32:06 am »
Oh really?
I might give MALA another go on a vertical machine.
fatfingers
  • Got UltraStiks?™
Re: Frontends
« Reply #12 on: February 01, 2007, 08:52:56 am »
Oh really?
MaLa supports Up X games and Down X games with one push of the joystick as well.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Buddabing
Re: Frontends
« Reply #13 on: February 01, 2007, 09:08:18 am »
I don't think this is such a good idea. Some of those files can be hundreds of megabytes. Do you really want your frontend to search a gigantic zip file every time it wants to display an image? Seems to me it would cause a huge performance hit.
Please read the wiki!
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
Re: Frontends
« Reply #14 on: February 01, 2007, 10:06:55 am »
I use MAMEWAH for both my vertical and horizontal cabinets and I have been toying with AtomicFE for to be used on my cocktail (that uses a PC monitor).
ahofle
Re: Frontends
« Reply #15 on: February 01, 2007, 11:14:15 am »
You don't have to unzip the entire file to get a snap out of it if properly implemented.  MAME32 has this feature and it's pretty much instantaneous.
Are there any frontends out there that allow manipulation of the games list with a mouse/trackball?
Kaytrim
  • I'm too nice a guy
Re: Frontends
« Reply #16 on: February 01, 2007, 11:39:13 am »
GameEx allows the use of the scroll wheel on a mouse (Z Axis)
Havok
  • Trade Count: (+17)
Re: Frontends
« Reply #17 on: February 01, 2007, 11:53:13 am »
I think they all do - the best thing to do is try them out. AtomicFE has four options for game list navigation:
  • keyboard/joystick/steering wheel
  • mouse/trackball
  • mouse/spinner
  • mouse/light gun/touch screen
ahofle
Re: Frontends
« Reply #18 on: February 01, 2007, 12:26:28 pm »
Well I did try Mala and Mamewah -- still need to try Atomic.  I guess I should've clarified what I meant by 'mouse manipulation'.  It would be nice to have a windows-like scroll bar that one could drag and drop the scroll 'slider' immediately to go from a game starting with 'B' to Zoo Keeper for example.  Slowly sliding the games list up and down with the mouse (or holding shift to move by X games) wasn't exactly what I meant.  Are there any frontends out there that have an actual scroll bar?
Havok
Re: Frontends
« Reply #19 on: February 01, 2007, 01:51:17 pm »
I haven't seen any with a scroll bar, but Mamewah is probably the best for that: my friend is running it, and when you spin the trackball fast, the list scrolls like crazy. With all the roms listed on his, I could spin through them all within seconds...
fatfingers
  • Got UltraStiks?™
Re: Frontends
« Reply #20 on: February 01, 2007, 02:04:44 pm »
I could be wrong, but I'm pretty sure you can increase the scroll rate in MaLa.
Where's loadman?!?!?!?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
loadman
    • MaLa
Re: Frontends
« Reply #21 on: February 01, 2007, 03:33:25 pm »
Well I was in the 'software' section where I think this post should be moved to
Yeah you can get MaLa scrolling fast with a mouse (trackball/strering wheel) but it does not have an actual 'scroll bar'
emb
  • Last login:September 14, 2018, 02:01:19 pm
    • Don Honerbrink
Re: Frontends
« Reply #22 on: February 03, 2007, 07:26:07 pm »
I've been a big fan of MaLa, except I (and a couple other friends), have had issues with it crashing frequently.
loadman
    • MaLa
Re: Frontends
« Reply #23 on: February 03, 2007, 10:11:04 pm »
The only time I have experienced this is when it comes across a 'bogus' snap pic or video.
Try and find if if happens at the same point(s)
disciple
  • Last login:February 17, 2007, 06:05:44 pm
Re: Frontends
« Reply #24 on: February 04, 2007, 10:14:05 am »
Easy as pie!
And the using the right hand stick you can jump up/down around 50 games each time.
freckleface
  • Last login:February 20, 2007, 07:04:55 pm
Re: Frontends
« Reply #25 on: February 04, 2007, 07:17:15 pm »
I'm fond of the folder menu in MAME32.  I didn't see anything like this in MaLa and GameEx.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Frontends
« Reply #26 on: February 04, 2007, 08:08:15 pm »
You can set up Mala, GameEx, and MameWah to give you the same result.... Just that it's not so easy, but it is far more flexible.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
spacies
Re: Frontends
« Reply #27 on: February 05, 2007, 10:01:46 pm »
Ok,
I just gave MALA a go in a vertical cocktail.
EASY!!!!!
And I found that you can scroll fast.
Nice work to whoever wrote this FE.
loadman
    • MaLa
Re: Frontends
« Reply #28 on: February 06, 2007, 12:35:19 am »
Ok,
EASY!!!!!
SWINDUS  ;)
