Author Topic: U360 problem  (Read 1112 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
U360 problem
« on: January 30, 2007, 10:16:28 pm »
I emailed Andy, but I thought I would ask here also.
I seem to have a problem with at least one maybe two u360s.  I upgraded the firmware from 1.5 to 1.7 on all four u360s.  Now one is not working at all, it was before.  Any idea?
The other three work fine except one has a small issue.  They all have the circular restrictor on and two of the three go in a circle when I test them, the other one goes in a square and hits the corners.  Any idea?
I b**ch. People listen!!
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
Re: U360 problem
« Reply #1 on: January 30, 2007, 10:24:33 pm »
I have no idea why one would have stopped after the firmware update.
As for the oddball square one...do you have a different map applied to that joystick?  Like the two that are working have the analog map applied and the one that is square has some sort of diagonal 4-way map?
 :dunno
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Donkey_Kong
    • CNC Machines
Re: U360 problem
« Reply #2 on: January 30, 2007, 10:29:52 pm »
I'm going to suggest re-assinging id's to them all in the ultra utility. This might take care of it.
Let us know.  :cheers:
squirrellydw
Re: U360 problem
« Reply #3 on: January 30, 2007, 10:52:27 pm »
They all have the analog map, I doubled checked that and even changed it than changed it back.
Here is what I just noticed, the one that is not working doesn't even have the light on when its pluged in.  The other one that has other issue the light seems to blink.
I did try re-assinging the IDs and that didn't work
« Last Edit: January 30, 2007, 10:54:17 pm by squirrellydw »
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
Re: U360 problem
« Reply #4 on: January 30, 2007, 10:58:46 pm »
I remember reading a post on here about this sort of thing when his were upgraded to 1.7.  I can't seem to find it right now.  Perhaps you could search around a bit...
Good luck,
If I do not respond to your post in a timely manner, feel free to PM me.
johnvv
  • Last login:June 19, 2012, 08:36:20 pm
Re: U360 problem
« Reply #5 on: January 31, 2007, 02:05:25 am »
It is my understanding that if there is no red LED, the PCB is dead.  Try it on another PC to be sure and/or plug it in as the only USB device on the bus.  If there is still no LED lit, you should probably contact Andy.
John VV
destructor
Re: U360 problem
« Reply #6 on: January 31, 2007, 04:23:01 am »
1. Disconnect all 3 working U360s
2 .Now reconnect fourth not working U360 to one from USB port where 3 U360s were working
3. Check if now this not working U360 will work and post it here.
squirrellydw
Re: U360 problem
« Reply #7 on: January 31, 2007, 09:55:18 am »
Still no luck.  Andy thinks the PCB is dead and I agree.  Not sure about the map issue but he is sending me two new boards.  Have to love Andy and Ultimarc, he really understands customer service.  I will not hesitate to order anything from  him.  He goes out of his way to help you and does it quickly.
Thanks Andy
« Last Edit: January 31, 2007, 10:01:52 am by squirrellydw »
rockin_rick
Re: U360 problem
« Reply #8 on: February 01, 2007, 12:38:21 am »
I found that thread, not sure if it will help you, though.  Worth checking out...
http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=91588
squirrellydw
Re: U360 problem
« Reply #9 on: February 01, 2007, 09:40:10 am »
I am using a laptop so I can't access the MB.   I will remember this when I order my new computer though
