Front End Support > MaLa Frontend
Can I do this with Mala?
millercentral:
loadman does understand what I'm after.. If I launch a game from the 270 orientation (as opposed to the 90degree orientation), I want the ability to remap the controls on the fly so that the launching side act as player 1 and the opposite side act as player 2 (when by default they are mapped in the opposite direction). I can do this manually by calling MAME with an alternate ctrlr file on games I'd like to do this with in this case.
Simply remapping the game controls is not always an ideal solution, because there or some games I want to be able to be launched from either vertical orientation (ie, walk up to whichever side you want, and the launching side becomes player 1).
Rather than a plugin solution, I'm requesting as a future feature request for mala, that this could be an option added to the MAME Config>Options>Auto Rotate section where only available when "Rotate MAME with MaLa" is selected and allows you to pick a ctrlr file to use for each orientation (0, 90, 180, 270). Just a thought...
Anyway, just a suggestion, still LOVING MaLa as a frontend. -james
loadman:
--- Quote from: millercentral on February 01, 2007, 05:17:03 pm ---Rather than a plugin solution, I'm requesting as a future feature request for mala, that this could be an option added to the MAME Config>Options>Auto Rotate section where only available when "Rotate MAME with MaLa" is selected and allows you to pick a ctrlr file to use for each orientation (0, 90, 180, 270). Just a thought...
FYI: I don't think a Plug-in or built into MaLa would not make any operational difference except that SWINDUS would have less code to change. :-)
loadman:
Lord Swindus said he will make a change so such a plug-in is possible with the next MaLa version
loadman:
It's now on the WIP page ;D
http://mala.arcadezentrum.com/wip.html
loadman:
New features were implemented in current version RC9 that should help you with this....
1) Did you change in options-controller-controller mapping you can add an extra mame parameter like:
-ctlrl 270.cfg
or....
2) Did you still need a plug-in created that edited mame.ini depending or orientation?
Just wondering :P
Navigation
[0] Message Index
[*] Previous page
Go to full version
