Author Topic: Run LED's off of +5V on Opti-wiz?  (Read 956 times)
coasternuts
  • Last login:January 11, 2010, 08:39:24 pm
  • Ouuuuch....I am not the worst game ever!!
« on: January 29, 2007, 11:07:24 am »
Is this possible or is that going to cause problems with the Opti-wiz?
Is it possible with only a couple, if several will cause problems?
The reason I'm asking is that I have one button that I'm lighting up on one panel,
and 4 on another panel.
Thanks.
Re: Run LED's off of +5V on Opti-wiz?
« Reply #1 on: January 29, 2007, 11:13:16 am »
1 and 4 shouldn't cause any problem at all. They draw practically zero current.  Now, if you wanted to add 25, maybe, but that few should not be an issue.
Note that does not apply to light bulbs, just LEDs.
Buddabing
« Reply #2 on: January 29, 2007, 12:33:14 pm »
Four LEDs may not work if they are wired in series. Depending on the LED, the voltage drop across each LED is approximately two volts.
Also, you should ask Randy how much current can be drawn. LEDs require roughly 20 milliamps, give or take. I'm guessing this will not be a problem.
I don't think it would break anything if you tried wiring it up, the LEDs should just dim or not work at all if the voltage or current is insufficient.
Don't forget a small resistor in your circuit to protect your LED(s). Not having a resistor may destroy your LED.
Please read the wiki!
« Reply #3 on: January 29, 2007, 12:35:10 pm »
I did assume he was going to wire in parallel in my answer.  Good to point this out.
ultrageek
  • Last login:August 23, 2012, 02:27:56 pm
  • If at first you don't succeed, you fail.
« Reply #4 on: January 29, 2007, 02:06:16 pm »
I have done exactly this and it seems to work ok.  I hooked the LedWiz to the +5V from the OptiPac and hooked 2 Led's up in series to the first 2 ports on the Wiz. NO JOY!
Changed the hookups to parallel and they glow like..well... things that glow! ;)
I did put a 15 ohm resistor in line with each Led.
Now, if I could just find a good way to control them...
-Lee
coasternuts
« Reply #5 on: January 29, 2007, 02:09:59 pm »
Excellent.  I have one panel which will only have two, so I figured that would probably work.
But the other panel I intend to do 4 buttons (2 LED each) in this configuration.
http://led.linear1.org/led.wiz?VS=5&VF=1.9&ID=20&N=8
My concern was that it would interfere with the Opti-wiz operation.
Thanks for the info.
RandyT
  • Last login:Today at 11:46:17 am
    • GroovyGameGear.com
« Reply #6 on: January 30, 2007, 06:19:57 pm »
My thoughts on this one are as long as you don't pull more current through the USB / PS/2 port than it it is able to deliver, you should be fine.
With non-powered USB ports, this is up to 500 ma (before any devices are factored in.)
So I don't see any problems with 2, 4 or 8 LED's being powered from the 5v line on the interface, unless you have an LED-Wiz on the same port with a bunch of LEDs being powered by it.
As mentioned before, make sure you use the correct resistors for your LEDs or else LEDs = junk  :)
RandyT
