Main > Main Forum
Lightweight transportable Cabinet?
Pages: << < (2/3) > >>
Cue-Ball:
--- Quote from: anthony691 on April 03, 2003, 10:39:24 pm ---Oh come on! That is hardly the same! I think an LCD in a full sized aluminum cab would be cool. I don't think just having a CP is even comparable to having a cab!
No, it's not comparable.  That's why we all build cabinets when it would be much easier to just do a CP or use the computer. But he already has a full size arcade machine and said he wants something portable.  "Portable" and "6 foot tall arcade cabinet" do not mix. :)
marcoval:
You know if I were wanting to make something portable and I was working on my 2nd cabinet, I would consider going cocktail..... Use lighter materials and I think you would be set.
neuromancer:
--- Quote from: marcoval on April 04, 2003, 04:56:47 pm ---You know if I were wanting to make something portable and I was working on my 2nd cabinet, I would consider going cocktail..... Use lighter materials and I think you would be set.
I had been thinking in those directions, but the weight of stuff adds up quick. Now I'm thinking of something along the lines of an AV cart. Some sort of wooden framework attached to the PC Case, on casters, with the monitor bolted down. It'll still be heavy, but I'll be able to move it into the living room and out on the porch easy enough.
Bob
MrArcade:
One thing to consider is weight....cabinets are heavy and do not move when two adults get into exciting gameplay.  If you make the cabinet easy to move...it will move during gameplay.  This would not be good in my opinion.
Distortion:
think of a cabinet cut off below the control panel.  It's been done before, and if you put it on a table, it's at a good height to be standing up and playing.
Go to full version
