Author Topic: Samples  (Read 970 times)
MYX
    • MYX Digital Blog
Samples
« on: January 25, 2007, 02:55:18 pm »
Texas got me thinking about sounds with his BkgMusic post.
I was listening to my son playing Donkey Kong last night. I was thinking about how bad the sound was. Every sound has a little tick noise on it which I thought was just due to a bad edit. Not sure, but aside from taking a mic and recording a cab, how could I get a better set of samples?
MarkRVP, you have a Donkey Kong, does it sound this bad on the original or just on the MAME samples? If the original sounds better, could you make a recording? I would be more than happy to edit it, clean it up and make a set for distro.
M    Y    X
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Samples
« Reply #1 on: January 25, 2007, 10:50:51 pm »
http://www.mameworld.net/samples/
Scroll down to June 25, 2006- there's an unofficial, more accurate DK set posted.
MYX
    • MYX Digital Blog
Re: Samples
« Reply #2 on: January 26, 2007, 09:38:22 pm »
Thank you! I have downloaded them, I just need to get them down to the cab.
M    Y    X
ArtsNFartsNCrafts
  • Last login:October 12, 2020, 09:22:50 pm
Re: Samples
« Reply #3 on: November 15, 2007, 07:12:22 pm »
Sorry to dig up an old post.  But when I run DK in mame32 (with samples), for some reason, the "mario running" sound stays constant at one pitch, whereas, on arcade machines, it's variable (varying in pitch with each step).
do i just have a bad set of samples or something?
DaveMMR
    • TeeVee Games
Re: Samples
« Reply #4 on: November 15, 2007, 07:26:23 pm »
Donkey Kong, for me, sounded horrible in Mame 0116 (that's the one with the big DK discrete sound updates).  Which version of Mame are you using?
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
Re: Samples
« Reply #5 on: November 15, 2007, 07:39:03 pm »
Actual DK boards sounded pretty crappy frankly.  Lots of distortion.  The SAMPLES probably sounded better than the original boards did and now with the new discreet sounds it sounds similar/same as the original?
