Author Topic: Wiring arcade button to Power on a PC  (Read 6198 times)
brianoneill
  • Last login:January 27, 2017, 04:44:59 pm
« on: January 24, 2007, 06:31:00 am »
Hi,
Anyone know how to do this ? I'd like to be able to power on the PC in the cab from a button (cherry switch) rather than from the PC hold up in the cab.
Can I use the normal wires I use from the buttons to the iPac ?
Cheers,
Brian.
Re: Wiring arcade button to Power on a PC
« Reply #1 on: January 24, 2007, 06:50:00 am »
Hi,
Cheers,
Brian.
Do not run the buttons through the ipac! Just relocate the power button on your computer and run it to a different switch.
You may want to consider not having it on the front of your cab.
brianoneill
« Reply #2 on: January 24, 2007, 07:02:55 am »
Thanks. Oh yeah. That was a bit stupid about the iPac connection. oooops.
Yeah. Side/top of cab might be safer.
So if I have a happs arcade button I just wire from the happs button to the two pins on the motherboard that control the power?
Cheers.
SirPeale
  • Green Mountain Man
« Reply #3 on: January 24, 2007, 07:06:35 am »
« Reply #4 on: January 24, 2007, 07:06:45 am »
Cheers.
If your motherboard turns on that way - give it a shot. I used to take a screw driver to manually jump it.
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
« Reply #5 on: January 24, 2007, 08:53:33 am »
If you have cats in your house you may wish to reconsider using a cherry switch for the power button on top of your cab. Cats tend to climb up on top the them cabnets (aka space heaters) for a nap, and it's way too easy for them to turn the thing on/off while stomping around up there.
Cutty
  • Last login:July 23, 2009, 10:48:30 pm
  • Cabin Cruiser
« Reply #6 on: January 24, 2007, 09:14:38 am »
I wish I thought of placement more before I wired my power button, its on top, but on the front left corner, and i never thought that would be the exact place people would stand and watch, while resting a hand on the top of the cab..........only got turned off once though, and no hi scores were at stake.
More Cowbell
  • That's just dumb!
« Reply #7 on: January 24, 2007, 09:41:34 am »
I simply hack a power strip and extend the on/off button to a switch wherever I want it on my cab. This way everything that I plug into it will power up with the same switch, (computer, monitor, speakers, marquee lights, etc.)
Very easy and very effective.
I've got a fever...
brianoneill
« Reply #8 on: January 24, 2007, 11:58:05 am »
thanks guys. actually that reminds me of another problem I am going to maybe have.
Until now I had a 22" CRT monitor in the cab. BIG BULKY and HEAVY. I m chucking that in favor of a now, out of a job, 17" TFT monitor.
I am wondering how the monitor is gonna get turned on each time I power up the cab !?
Kaytrim
  • I'm too nice a guy
« Reply #9 on: January 24, 2007, 12:00:47 pm »
Keep the 22" if at all possible man,  a 17" monitor is small for an arcade machine.
brianoneill
« Reply #10 on: January 24, 2007, 12:07:12 pm »
well the 17" is flat screen and the 22" is CRT so not as much difference as you might think.
Also, the 22" weighs a tonne! The amount of times I've had to move the cab around with that thing in it is real annoying.
Actually, on other question..free for all now :) but what guage wire do I need to connect up my buttons to the iPac. I have it already wired up but want to re-wire (cleanly). No idea what gauge(?) the wire is. At a guess 22 gauge ?
More Cowbell
  • That's just dumb!
« Reply #11 on: January 24, 2007, 04:32:06 pm »
22. 23. Whatever it takes.  ;)
I've got a fever...
Huskerfan
  • Last login:October 05, 2021, 11:40:38 pm
« Reply #12 on: January 24, 2007, 04:56:48 pm »
"220. 225. Whatever it takes."  Not sure how many movie buffs are in the audience. ;D
I used 20 gauge "bell wire" that I bought from Home Depot.  It comes in red and white strands.
rcrules
  • Last login:August 07, 2023, 01:57:25 pm
« Reply #13 on: January 25, 2007, 03:36:41 am »
"Nice shot. what did you use, a 38?"  "38, 39, whatever it took."
