Author Topic: Odd problem with Simpsons machine  (Read 1129 times)
jasonorme666
  • Last login:May 06, 2008, 09:35:50 am
« on: January 22, 2007, 07:22:49 pm »
Hello,
I'm having a rather bad day today..
First off, I was playing X-Men 4 player on my The Simpsons 4 player cabinet.
I go to swap to Turtles In Time 4 player, unplug it all, get the board, reconnect the harness etc and it comes on.
I press the test button on the PCB to change the settings, I then notice the player 1 controller isn't working which is odd as I was only just using that joystick..
I turn off the machine, turn it back on and am greeted to a black screen, even the light to indicate the coin mech is working is off (a wire which links to the harness), however the marquee is lit up and there is indeed power going to the monitor.
I unplug the harness and reconnect it, while reconnect the screen goes all sort of colors, when fully connected again, just a black screen.
I've followed all cables, even swapped the PCB back over and now getting the problem with X-men.
Can anyone please help me?
Thank you.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Odd problem with Simpsons machine
« Reply #1 on: January 22, 2007, 09:05:38 pm »
Get a meter and buzz through your harness.... Given that you're now also getting the problem with the other board, you can rule out a fault on the boards themselves. This is almost certainly a break in a wire somewhere.
Buzz through each wire in turn until yo find it then run a new one.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
jasonorme666
« Reply #2 on: January 22, 2007, 09:24:46 pm »
Thanks for the help.  :cheers:
Also, do you know of anything that can be used to aviod having to solder wires onto the harness?
Also, what sort of wire would I need in order to re-wire if needed, is it any specific type?
Fozzy The Bear
« Reply #3 on: January 22, 2007, 09:48:32 pm »
Yes.... Assuming the break is not near the very end... just cut the offending wire out, leaving a couple of inches at each end and use a small chock block at each end to connect the new one into that.
Just standard hook up wire..... It comes in various gauges, 16, 18, 20, and 22 are the most common ones. In a harness like that, any of those should work.
Another thing to check before you cut any wires, is that, if there are any molex or similar connectors in the loom, they are tight and the pins are well pushed in place and making good connection.
Best Regards,
« Last Edit: January 22, 2007, 09:51:14 pm by Fozzy The Bear »
jasonorme666
« Reply #4 on: January 22, 2007, 09:50:55 pm »
Great
Thanks again for the help  :notworthy:
jasonorme666
« Reply #5 on: January 23, 2007, 03:43:50 am »
Somone else suggested that it could be a problem with the power supply.
Thats its not giving enough power to the harness..
Unyet, the marquee is lit up and the monitor power is definatly on.
Unfortunalty, I don't know what is safe to touch on the power supply, there are many plugs down there, all of which appear to be connected.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #6 on: January 23, 2007, 12:18:49 pm »
MARQUEE LIGHTS ARE NOT POWERED BY THE POWER SUPPLY!
NO MORE!!
jasonorme666
« Reply #7 on: January 23, 2007, 12:38:56 pm »
Okay..
Well..
I got a multimeter, but I havnt a clue how to use it.
jasonorme666
« Reply #8 on: January 23, 2007, 05:55:59 pm »
I beileve I've narrowed down the problem to the power supply.
It only gives me a 0.02 reading in both the +5v and +12V..
I've ordered a new power supply.
