Author Topic: MAMEWAH v1.62b13 for BETA testing!  (Read 2283 times)
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
Re: MAMEWAH v1.62b13 for BETA testing!
« Reply #1 on: January 19, 2007, 06:21:53 pm »
Can someone PLEASE download b13 from mameworld.info and re-post it here as I can not download it from mameworlds servers...long story.  Thanks!
« Reply #2 on: January 19, 2007, 07:37:26 pm »
FrizzleFried
    • Idaho Garagecade
« Reply #3 on: January 20, 2007, 11:40:57 am »
Thus far all looks good...but the HISTORY.DAT implementation needs work...it's currently very rough looking.   Perhaps a button to click to get to this data....or if you want to keep the current setup,  at least scroll the text smoothly.
That aside,  the update kicks ass.  It fixes issues I had with my current vertical cabinet...but I just can't use the History.dat feature until it can be presented a little better...
« Last Edit: January 20, 2007, 12:18:58 pm by FrizzleFried »
« Reply #4 on: January 20, 2007, 04:53:38 pm »
Have a look in mamewah.cfg...that is what the 'TOGGLE_HISTORY_DAT_DISPLAY' input is for.
I knew some people would want pixel scrolling, but I didn't want to jump through hoops to do it.  When I start using DirectDraw that should be easy... You might find with the above shortcut that the line scrolling is more acceptable when scrolling through manually.
FrizzleFried
    • Idaho Garagecade
« Reply #5 on: January 20, 2007, 09:42:51 pm »
I found that entry in the .CFG file...any way to make it pop up a separate window above the menu (like the OPTIONS menu pops up for example)....?
« Reply #6 on: January 22, 2007, 04:55:45 am »
Nope, but if you want to do that you could use JFath's HistView: http://www.fath.us/unprotected/projects.html
FrizzleFried
    • Idaho Garagecade
« Reply #7 on: January 22, 2007, 10:07:59 am »
After a little tweaking with my current layout,  I have it set up to show the title screen jpg first,  then go in to the animated preview.   If I click the CREDIT 1 button,  the history screen replaces the animated preview until I click the CREDIT 1 button again which makes it disappear and the title screen come back on.
The only MINOR issue I can see is that when I click the CREDIT 1 button to go back to the title screen,  it then stays the title screen...it won't pick the animated preview back up until I move off that game and come back.
The corrected vertical aspect ratios work kickass...thank you!
I can't really test the vertical filter as I have already removed all horizontal ROMS from my vertical cabinet....when I get to my horizontal cabinet I will be able to test this...
Request/Suggestion for next release (on top of all the other important stuff like Animated GIF support):  Smooth scrolling (pixel scroll?),  the ability to turn on and off the auto-scroll as well as perhaps a speed setting?   The ability to attach an image to a button...it would be pretty cool to be able to hit a button to see the CONTROL PANEL or CABINET from a game...
Thanks Minwah!
« Reply #8 on: January 22, 2007, 11:50:47 am »
OK will look at this, should be a pretty easy fix.
I commented above on this, basically don't hold your breathe!
You can turn it off by setting the delay to 0.  I agree scroll speed would be handy, I'll add that.
Well not exactly currently possible, but that is pretty much what some people achieve with the help of JCrouse's CPViewer or Howard's Johnny5.
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
« Reply #9 on: January 22, 2007, 07:57:17 pm »
I'm having a problem with list generation (mame32b109)  I get an error in my log which says ' does not exist in MsgExecCmd'.  Here's my ini file:
### AA_mame.ini (mamewah v1.62) ###
emulator_title                            Arcade Games
### List Generation Settings ###
rom_path                                  c:\mame32\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file                           c:\mame32\catver.ini
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      C:\Mamebat\default.bat [name]{nodosbox}{nosafelaunch}
post_emulator_app_commandlines
general_app_commandlines                  C:\histview\histview.exe -r=[name]
### Artwork Settings ###
artwork_image_paths
c:\mame32\snap;c:\mame32\marquee;c:\mame32\marquees;c:\mame32\cpanel;c:\mame32\cabinets
movie_preview_path                        c:\mame_videos
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file                          auto
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                gamelist_slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
Am I doing something stupid?
FrizzleFried
    • Idaho Garagecade
« Reply #10 on: January 22, 2007, 08:57:07 pm »
D0h...I thought you meant THIS version...(in your first post that is).
