Author Topic: saturn emu?  (Read 1099 times)
daywane
  • Last login:Yesterday at 02:08:40 pm
  • GRRRR!
saturn emu?
« on: January 15, 2007, 04:19:49 pm »
any worth a darn ?
tried the one for Atomics plug and play. I did download damon tool also.
I have not got this one running yet.
tried another saturine??? some thing like that. I did get 2 game to run but very slow
could be the PC I tried
1.2 gig cpu
512 meg ram
xp home sp2
my saturn bit the dust (version 1) I was working on disk swaps
funds kind of tight now,  :banghead: thought I would try emu's till I find a version 2 and track down a mod chip
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: saturn emu?
« Reply #1 on: January 15, 2007, 05:10:14 pm »
Hi,
What is exactly your problem with the Saturn module?
daywane
  • GRRRR!
Re: saturn emu?
« Reply #2 on: January 15, 2007, 07:19:01 pm »
I get cd drive not ready.
I heve not figured out how to use it yet.
not as simple as plug and play as the other cosoles you hace ;)
youki
    • Atomic Front End
Re: saturn emu?
« Reply #3 on: January 15, 2007, 07:52:45 pm »
You are trying to use directly a Saturn CD with the emulator or you are using a CD image on your Hardrive?
I think the first option is not possible.
daywane
  • GRRRR!
Re: saturn emu?
« Reply #4 on: January 16, 2007, 09:08:05 am »
I have tried both.
backed up cd (worked with swap method on real saturn)
and the cue files on HD.
the plug and play SSF will not let me do anyhing. I start the emu and the
screen shows cd not ready.
mouse is not visable. I get stuck.
ctrl alt delete , end progam is all I can do
youki
    • Atomic Front End
Re: saturn emu?
« Reply #5 on: January 16, 2007, 04:58:34 pm »
 i will try to find if i have a saturn iso somewhere. And try tomorrow. I'll keep you inform/
youki
    • Atomic Front End
Re: saturn emu?
« Reply #6 on: January 18, 2007, 09:07:56 am »
Ok as i said in PM  , this is how to proceed to make work the Plugnplay saturn module with the last version of Daemon tool.  (the version seems to have changed since the module have been released)
I tested only on Windows XP.
Here how to proceed :
Download Daemon-tools 4.08 X86  here :
http://www.daemon-tools.cc/dtcc/download.php?mode=Download&id=81
Install it.
Install the Saturn plugnplay module.
Copy your roms in your  <Atomicfe>\plugnplay\saturn\roms folder
Go in program files\DAEMON tools folder .
   - copy the file DAEMON.EXE  which is here to  <atomicfe>\plugnplay\saturn folder  (replace existing one)
Right click on the DAEMON tools icon in the task bar (near the clock on the bottom right of windows desktop)
    choose "option"
        -untick Secure Mode
        -untic Automount
  then
    choose "Virtual CD/DVD-ROM"
        -then "Device 0 : .... "
        -then "Set Device Parameter"
            -Uncheck "Auto insert Notification"
Run Atomic.exe , choose Saturn , choose your rom  and play!
daywane
  • GRRRR!
Re: saturn emu?
« Reply #7 on: January 18, 2007, 08:52:13 pm »
that was quick.
Thanks for the help.
