Main > Main Forum
Particle board or MDF
Nervous:
How about plywood? That's pretty much all I ever use.
It holds screws really well, and doesn't weigh as much as MDF.
T-molding hasn't been a problem either.
_Iz-:
Plywood doesn't paint up as nicely as MDF.
Jakobud:
I used 5/8" MDF. If you don't mind shelling out a little more for MDF rather than particle board, you will be very very satisfied.
Nervous:
--- Quote from: _Iz- on April 02, 2003, 03:00:30 pm ---Plywood doesn't paint up as nicely as MDF.
You're absolutely right. MDF does look pretty good when painted.
SirPoonga:
plus patching mistakes with mdf is so easy when combined with wood putty....
