Author Topic: MAMEWAH Problem, says loading and nothing happens  (Read 1117 times)
needlesmcgirk
  • Last login:September 15, 2009, 10:54:31 pm
« on: January 09, 2007, 11:53:37 am »
I'm trying to get MAMEWAH to work using an NES and SNES emulator and I'm having issues.  I have gone through the .ini files and done that, but I guess something is missing.  I can get the games list to genereate for both, however on the SNES when I load a game, a screen says "loading [game]" and then it goes away and nothing happens.
When I try it for NES, I get an error saying "rom not found" and the whole thing messes up.  I'm not sure what I am missing here.  I have postes my .ini for the SNES here:
### List Generation Settings ###
rom_path                                  D:\Profiles\williaki\My Documents\Emulate\SNES
rom_extension                             smc
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       D:\Profiles\williaki\My Documents\Emulate\SNES\ZSNESW.EXE
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      c:\mame\snap
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
Havok
  • Trade Count: (+17)
Re: MAMEWAH Problem, says loading and nothing happens
« Reply #1 on: January 09, 2007, 12:16:57 pm »
Are you able to run the emulator without Mamewah? Also, what version of Mamewah are you running?
« Last Edit: January 09, 2007, 12:18:29 pm by Havok »
needlesmcgirk
« Reply #2 on: January 09, 2007, 01:30:21 pm »
Yes, I have tested both emulators and ran the same game I was trying in Mamewah and it works perfectly.  I am using Mamewah v. 1.61.  I haven't tested out mame games yet because I don't have them on my laptop.
Havok
« Reply #3 on: January 09, 2007, 02:24:13 pm »
Try running Mamewah with the {nosafelaunch} switch.
Also, going forward - if you plan on using version 108 or newer of Mame, you will need to upgrade to Mamewah 1.62...
« Last Edit: January 09, 2007, 02:32:26 pm by Havok »
needlesmcgirk
« Reply #4 on: January 09, 2007, 04:58:36 pm »
^ When I do that, nothing happens.  It does not say loading or anything.  Can anyone see if there is something wrong with my .ini file?
needlesmcgirk
« Reply #5 on: January 09, 2007, 05:22:13 pm »
I downloaded the 1.62 beta and I can't figure out how to use that at all.  It seems like it is totally different with the .ini files, and I can't find a read me or anything.  I could really use some help over here, I know you guys know how to use this.  I'm begging!
Edit: I have been messing around with it and I may have figured it out.  We'll see.
« Last Edit: January 09, 2007, 07:24:29 pm by needlesmcgirk »
« Reply #6 on: January 10, 2007, 11:22:18 am »
Take a look here for JCrouse's useful ini files.  If you get stuck it's best to ask at the Mamewah board (@ Mameworld).
