Software Support > PowerMAME
PowerMAME plug-in??
swindus:
Just for the record: MaLa does not require any config files per game for the LEDWiz or the UltraStik. You can overwrite the defaults when you want some custom lightning or input.
arzoo:
--- Quote from: swindus on January 09, 2007, 10:49:34 am ---You can overwrite the defaults when you want some custom lightning or input.
That's what I was referring to - if you remap the inputs for a game (via mame), you'll need a custom file.
southpaw13:
Like I said, I was never mad at Mike, BUT a little upset with Randy for not having software support. Back to my original question: Should this forum be closed (to help out Mike) and should an LEDWIZ or just an LED forum be added?
Question about Mala: Does it matter which chipset you are using on your motherboard because there was an initial problem with ATI vs NVIDIA that Mike worked around to get the USB ports to work properly.
arzoo:
--- Quote from: southpaw13 on January 09, 2007, 01:51:20 pm ---
You may want to ask loadman or edge - they coded the LEDWiz plugin for MaLa. I'm pretty sure they worked with Randy.
MikeQ:
--- Quote from: southpaw13 on January 09, 2007, 01:51:20 pm ---Like I said, I was never mad at Mike, BUT a little upset with Randy for not having software support. Back to my original question: Should this forum be closed (to help out Mike) and should an LEDWIZ or just an LED forum be added?
I PM'd Saint and told him he could do whatever he wishes with the forum and to remove me as moderator. It doesn't bother me if it still exists. Letting my website expired stopped most of the unwanted email.
Anyone doing LEDWiz software interfaces would have to get the info from Randy and he is probably giving them my code. The code has the workaround for Nvidia chipsets.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
