Main > Main Forum
Best 3rd party control panel
Lilwolf:
1) Building the control panel is MUCH easier then building the cab if you spend some money on a good encoder. IPacs, MK48/64, Hagstroms, are all GREAT (and the new one I hear is good. Too new to get it capitialized reply without getting one myself... but it will probably be GREAT).
2) This converts an arcade joysticks and buttons to a keystroke. So the joystick is really like having 4 buttons (one up, down, left and right).
3) If you go with ipacs, the wiring is super easy (screw tabs). (I went with a MK64 because it used to be the only big one... and it has some REALLY SWEET new features coming out!)
4) The last thing to know is there can be ONE ground! So you wire the ground from the encoder to a button (or joystick direction) to button to button... you can daisy chain them (one to the next) or star it out (one breaking it up to many).
5) Then you have ONE wire to the other side of the button or joystick to the other side.
It really really is easy and there are tons of examples out there.
And dont forget
you ALWAY get us... warm snuggly feeling inside should be felt now... hugs....... (WARNING! DONT ACCEPT HUGS AND WARM SNUGGLY FEELING WITH HOWARD C... HE WILL EAT YOU ALIVE!!!)
--- Quote from: brianoneill on April 02, 2003, 07:29:20 am ---OK. So i've checked up on this I-Pac and it seems there are 2 versions. I-Pac2 and I-Pac4.
If I wanted a 2 Player panel with also a dedicated 4-way joystick for Pacman and such.... would I need the i-pac4 as the i-pac2 only has... 2 joy inputs ?
2slk:
Brianoneill,
Take the plunge and build your own panel then. It's a great learning experience and very gratifying. Besides, those damned retail panels are way too expensive. Also, shortly after you buy the panel, you'll start wishing it had 'this' instead of 'that' or want to change the configuration and guess what? You'll be building your own anyway. Don
brianoneill:
thanks for your help.
I might just try it ;)
