Author Topic: ROMS not found in front ends - puzzled.  (Read 1618 times)
benarcade
  • Last login:October 13, 2023, 04:59:32 pm
« on: December 31, 2006, 01:32:28 pm »
I've now installed both mamewah and mamefe and neither can find my roms. I've pointed to them exactly using the ini and setup (respectively) and neither finds roms. Roms do exist. I can command line mame.exe with the rom name and it plays just fine. roms are under the standard c:\mame\roms file.
Frustrating. Everything is a gd task.
Any ideas?
headkaze
  • 0x2b|~0x2b?
Re: ROMS not found in front ends - puzzled.
« Reply #1 on: December 31, 2006, 02:09:55 pm »
Can you add " >test.txt" to the end of your Mame command line option for MameWah, then open test.txt, and see what error message you get.
jWin
  • Last login:December 17, 2014, 01:50:10 am
« Reply #2 on: January 02, 2007, 11:53:36 am »
try adding your rom path in the mame.ini as well
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
« Reply #3 on: January 02, 2007, 01:43:17 pm »
I will save you hours of heartache....
...if you have MAMEWAH 1.61 and are trying to use it with MAME .107+,  don't...it is such a pain in the ass that you will want to shoot yourself before you get it going.
Dump it and get MAMEWAH 1.62b12.
Your problem is that the front ends aren't generating LISTS for you...
BLah247
  • Last login:June 12, 2014, 08:01:53 am
« Reply #4 on: January 05, 2007, 06:24:46 pm »
I was having the same problem.  Guess I'll get the beta and check that out.
mrclean
    • Guscade
« Reply #5 on: January 05, 2007, 06:26:34 pm »
I'm using Mame 111u2 and Mamewah 1.61 working fine for me .. just use kricks file if you need help ill post my ini for you
2,370,650 Gun.Smoke
BLah247
« Reply #6 on: January 05, 2007, 06:32:01 pm »
Well that took me all of 5 mins to download the beta and install and it worked fine.  I'm still at least a month out from finishing my cabinet and getting the pc in it and such so I'll wait and see what revision is out by then.
