Author Topic: Crystalfontz Serial LCD Display  (Read 1624 times)
Red 5
  • Last login:January 08, 2021, 10:30:51 am
  • Do something stupid and we will make you famous
« on: December 29, 2006, 08:08:29 pm »
Anyone know anything about these? Good, Bad
http://www.crystalfontz.com/products/634/index.html
$60.00 not bad in my book
I really have no clue why I need this, but for some reason I think I do.
Thanks,
Jon
I accept CASH, Hostages and Gold Krugerrand
loadman
  • Last login:August 17, 2020, 03:23:55 am
    • MaLa
Re: Crystalfontz Serial LCD Display
« Reply #1 on: December 29, 2006, 09:32:48 pm »
Not bad...  ;)
Depends what you want it to do?   :dunno
Let us know and we can give you options & advice.
Red 5
« Reply #2 on: December 30, 2006, 05:38:31 am »
I was thinking of just displaying in game info.
Probally using Silver Fox's program.
I don't think I need info scrolling while in the FE.
Just somthing else to add for more "bling"  :)
Thanks,
Jon
headkaze
  • 0x2b|~0x2b?
« Reply #3 on: December 30, 2006, 07:47:39 am »
They look fine to me. Are they backlit though?
Red 5
« Reply #4 on: December 30, 2006, 08:24:54 am »
The one I'm looking at is "White LED Negative Backlit" and if I'm reading it right
the brightness can be software controlled.
Jon
loadman
    • MaLa
« Reply #5 on: December 30, 2006, 04:28:53 pm »
Thanks,
Jon
You might want to consider a bigger one. I'm not sure if Silver prog supports the smaller displays
Red 5
« Reply #6 on: December 31, 2006, 05:47:56 am »
The one I'm looking at is 20 x 4.
It looks like Silver Fox's software now supports it.
Jon
headkaze
  • 0x2b|~0x2b?
« Reply #7 on: December 31, 2006, 11:57:42 am »
What FE do you use? Mala probably has support for this LCD via loadman's plugin, I know the GameEx plugin I'm working on supports all LCD's that Silver's LCDGen supports.
If you do decide to go for this LCD, you can test it with my LCDTest application.
Other FE's like MameWah and AtomicFE have support for this using LCDGen.
Red 5
« Reply #8 on: December 31, 2006, 01:49:06 pm »
Right now I'm leaning towards MameWah, I know pretty much how to use it. I have also downloaded Mala and Atomic.
I will give your software a try when the display arrives.
Thanks,
Jon
loadman
    • MaLa
« Reply #9 on: December 31, 2006, 06:02:48 pm »
Jon
Kewl...   I should have looked first   ::)
Red 5
« Reply #10 on: January 11, 2007, 08:51:02 pm »
It showed up about an hour ago. Tried your software, worked like a champ.
Thanks,
Jon
