Author Topic: Installing Car Stereo on Kia Sportage...  (Read 4616 times)
lokki
  • Last login:June 29, 2017, 12:57:48 pm
« on: December 27, 2006, 05:06:16 pm »
Hi,
I'm installing a new stereo on my 98 Sportage. Trying to figure out the wiring but I'm having a hard time.
Is there such a thing as universal color code?
Red Power
Black Ground
For speakers?
Color +
color stripped -
Been trying to find wiring diagram with out much luck.
any help would be appreciated.
jam92102
  • Last login:May 10, 2013, 07:02:22 pm
  • Help Me Please!!!!
Re: Installing Car Stereo on Kia Sportage...
« Reply #1 on: December 27, 2006, 06:15:35 pm »
Sometimes there's common wiring but most the time if you're not using a wiring harness you have to use a volt meter to determine what is what.  It's easiest to go somewhere like best buy and buy a wiring harness for your car.  It makes it a lot simplier, and if you ever want to go back to the stock radio you just take the wiring harness out.
lokki
« Reply #2 on: December 27, 2006, 07:09:22 pm »
Thanks,
I for the tip. I found a harness at Best Buy.
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
« Reply #3 on: December 28, 2006, 12:38:35 am »
A harness is by far the best way to go on car stereo installs. Car manufacturers tend not to follow a universal code the way an electrician wires a house.
Another reason is, when you splice the wires, you could end up with altenator or other motor noises.
Last reason I can think of....most harnesses are around $10-$15 and make the job much easier and neater.
Xam
Can't talk to a psycho like a normal human being.
SirPeale
  • Green Mountain Man
« Reply #4 on: December 28, 2006, 01:26:05 pm »
Harness is definitely the way to go.
I cuts costs where I can, but for time/energy/effort, this is a plug-and-play solution.
« Reply #5 on: December 28, 2006, 01:27:19 pm »
You can usually look up the color coding for any given car, too, rather than take a DMM to the wires.  The DMM won't help in identifying some of them (like the antenna wire).
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #6 on: December 30, 2006, 04:41:15 am »
I know you stated you found a wiring harness, but for anyone else.....
http://www.designtech-intl.com/wire.asp
http://www.installdr.com/
http://www.directwholesale.net/diagrams/diagrams.asp?link=BULLDOG
Bookmark those in case you think you might ever contemplate messing around with your car stereo.
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« Reply #7 on: December 31, 2006, 12:59:16 am »
In a KIA, aren't the sounds systems "load bearing"? :cheers:
-J
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
