Main > Main Forum
Is 7-volts too much for a 5-volt requirement?
<< < (2/2)
ChadTower:
If I recognize that chip properly, it's just an eeprom.  No voltage changing whatsoever.
Havok:
Why can't you pull 5v from the computer power supply? I would think that is the best solution. Both the Ipac and Keywiz\GPWiz have a 5v tap for just this thing. Worse case - buy a universal adapter for $10 and wire that up...
Ed_McCarron:
--- Quote from: ChadTower on December 12, 2006, 11:11:54 am ---
ATMEL is all about microcontrollers now... Judging by the fact that its the only chip there, thats what I'd assume it is.
rockin_rick:
--- Quote from: Ed_McCarron on December 12, 2006, 12:46:36 pm ---
Yes, it is a microcontroller.  Feeding it 7V will not work.
Kevin Mullins:
Maximum DC voltage listed is 6.0v ......... DC
http://www.atmel.com/dyn/resources/prod_documents/doc1477.pdf
As already mentioned....
Use the 5.0v DC from a PC power supply if this is indeed for a MAME project or something similar that is using a PC.
Navigation
Message Index
Previous page
Go to full version
