Author Topic: Help! Disk is not formatted/Back-up Protocol  (Read 897 times)
mpm32
  • Cheesecake Master
  • Last login:November 20, 2018, 09:25:14 pm
« on: December 11, 2006, 05:32:06 pm »
I have an external HD and when I go to access the files it says "disk J is not formatted, would you like to format now?"
I click no because I don't want to reformat and lose data.  Can I fix this without losing data?  I hava a ton of pictures and music on this drive.
Can anyone help?
« Last Edit: December 11, 2006, 08:22:56 pm by mpm32 »
mpm32
  • Cheesecake Master
Re: Help! Disk is not formatted/Back-up Protocol
« Reply #1 on: December 11, 2006, 08:25:51 pm »
OK,  I found a data recovery product that looks like it will restore my files.  What I need to know is what everyone is doing for backing up their picture and music files.
Should I have multiple external drives?  What should the backup protocol be?  I have no clue how to do this.  My wife wants me to back-up to a cd or dvd, with the amount of data I have this would be impractical.
Any advice?
boykster
  • Last login:May 25, 2021, 12:13:15 am
  • The cake is a lie!
« Reply #2 on: December 11, 2006, 08:49:25 pm »
Depends on how much data you're talking about.  I use RAID5 arrays for my data, but even RAID is really considered a proper "backup" solution, just a redundancy in case of not quite catastrophic failure.  For really critical files -> digital photos, home movies, finacial records, etc, I do periodic dumps to DVD just as a sanity check.  I have had a RAID5 array go down completely so I like that extra sense of security.
Other options are tape backup, periodic disk mirroring, etc.
 :dunno
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:May 04, 2024, 09:08:32 am
« Reply #3 on: December 11, 2006, 08:59:20 pm »
I backup critical files to several computers around the house. This helps me avoid data loss from single computer failure. I then copy the entire set of critical data (22 gigs of family photos alone!) onto a portable hard drive, then bring that to work and mirror it off to my work PC. This helps me recover in case of a disaster in the house. Finally, I periodically burn a set of DVDs and put them in a fire-resistant lock-box in the house.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
jbox
  • BYOAC Poet Laureate
  • Last login:November 30, 2007, 08:00:54 am
« Reply #4 on: December 11, 2006, 10:07:33 pm »
Wait, I thought this forum *was* your backup drive for those "important photos"?  :cheers:
Done. SLATFATF.
mpm32
  • Cheesecake Master
« Reply #5 on: December 11, 2006, 11:07:55 pm »
Don't worry, no cheesecake photos have been lost.
jbox
« Reply #6 on: December 11, 2006, 11:15:01 pm »
Whew!
Done. SLATFATF.
